exxxviii wrote:
lightheir wrote:
Cars should be FINE with even 350lumen lights
so long as you're not beaming them directly into the driver's eyes.
Oncoming car traffic is wayyy brighter than a runner's puny single headlamp aimed at the ground. Be extra courteous to approaching RUNNERS who will get blinded by even low-lumen lights if they're not using a headlamp themselves.
You can have a million lumens, as long as they are aimed at the ground. But, the problem is lux, not lumens. And the problem here is that runners are likely looking up at cars and blinding them. In that scenario, lumens are irrelevent. You are putting a narrow beam directly into the eyes of a driver, which can be a lot of lux, because it is less dispersed.
Comparing a car headlight lumens to a runner headlamp is apples and oranges. Car headlights produce a lot of lumens, but the beam patterns are designed to throw light at least 50m down the road and about 6m across the road. That is a huge area and dilutes the lux. Further, most of that pattern is cut off and below eye-level of oncoming traffic. So, the lux hitting the eyes of a runner or another driver is managed. However, when you point your headlamp, with its narrower beam pattern, directly into the eyes of a driver, the lux is much higher than lux from oncoming traffic. (You got it right with the last statement... but why would an oncoming runner get blinded when a car would not? They are the same.)
I agree that directing the light is a key feature.
Alas, I haven't found a runner headlamp that will cutoff the beam so it won't be blinding (unlike car lights.)
As well, runners typically do NOT look at cars as you suggest. The ONLY time I ever do that is when I intentionally do so when a car is clearly going to hit me and doesn't see me (cars pulling out of driveways into my path is the most common scenario - you can see the super jerk stop they do when they realize I'm there.) Unfortunately, the lack of beamforming of runner headlamps means that the spillage itself can be pretty blinding, even if the beam is mainly aimed at the sidewalk.
I say my 500+ lumen headlamp is like a car headlamp on hi beam due to subjective comparison. Not scientifically correct, but if you stand facing my car where a runner would be facing oncoming traffic, the headlamp's brightness is very similar to the car beam on high (the car lux is likely higher as you state but has beam cutoff to reduce the spillage.)
