Hamstring Pain
All,
I am having some pain near my left knee while biking. The pain is in the side towards the back (see the highlighted line in the attached picture). The highlighted circle is where there is some restriction after the long ride. There is no problem during running and swimming.
Background: I am training for the Houston 140.6 race and have had a solid 6 months of training under my belt including Austin 70.3 in October 2017. This pain surfaced after my 83 mile ride on Saturday, February 3rd. After that, I did a 3 swim workouts and couple of runs (16 miles and 7 miles) with no issue. I also biked slowly for an hour on my indoor bike. It wasn't bad. So, I did another 75 mile ride on Saturday, February 10th after taking an ibuprofen. The pain has resurfaced.
Could you please advice on how to resolve this?
Aspiring 140.6 Triathlete
Re: Hamstring Pain [vinaypandey] [ In reply to ]
If the red circle is on the lateral side of your leg, I believe that is the area that gets irritated when you are having IT band issues. The line looks to be the tendon (not hamstring muscle) that runs just above the back of the knee. Again, hard to say.
I don't know what you are currently doing for injury prevention, but I find that foam rolling helps a lot to manage/prevent IT band pain. I have had pain in that tendon behind the knee before, but it was the result of a specific action (also on the bike) where I ended up spinning my gears. It did not go away all season, but it was manageable.
If rest is not your cup of tea, then I would recommend riding as long as you can without experiencing pain and then slowly build from there. OR concentrate on the other two disciplenes for a bit and then come back to cycling. And foam rolling.
Probably a bike fit issue, since you don't feel it Swimming or Running. Check your cleat position and see if your knees are tracking straight. Setup bike trainer in front a mirror. If your knees are turned inward, you will have more pressure on outside of your leg.
Re: Hamstring Pain [toastygloveman] [ In reply to ]
Thanks for the reply. The red circle is on the lateral side. I did extensive foam rolling yesterday. Personally, I don't think this is an ITB issue as it is not flaring up during my long runs. I am planning to take a break from biking for a couple of weeks and will come back to it after full recovery. Meanwhile, I will increase my run and swim mileage.
I think that is a good plan. You could probably could mix in some short trainer recovery rides.
I had a self diagnosed IT Band issue that only flared up while on the bike a couple of years ago. I don't know if it was actually the IT band, but whatever it was it did not effect me while running. I would just get a dull ache where your circle was during long cycling rides.
Re: Hamstring Pain [jdais] [ In reply to ]
Thanks! This could be a bike fit issue. I am planning to check it in the next couple of days.
Thanks for the insight. I really appreciate it.
I would be remiss if I forgot to mention that you should be foam rolling after workouts, not before... I don't know your level of experience with this sort of thing, so I thought I would mention it.
Best of Luck!
Thanks! Yes.
