I have both a Flo 60 and a HED Jet 6 Flame Rouge front wheel and I am trying to decide which one to keep. The Flo is a touch wider (24.5mm vs 23.5 mm according to my calipers). The Flo rim also has what appears to be a more modern aero shape, the Flo has a rounded leading edge with mostly flat sides while the HED has more of a rounded V shape. I believe the HED wheel is a ‘Stallion’ build - Both wheels have twenty bladed spokes and both are aluminum clinchers with a non-structural carbon fiber fairing. The HED is probably a touch lighter but not enough to worry about IMO. I have been running GP4000s 23mm tires and will probably continue to do so.
So which one do I keep?
I have two front wheels because I was running a Flo 60 Set and picked up the HED Jet 6 Wheelset because I was looking for a wheel with a powetap hub :-) If I keep the Flo front I will probably peel the stickers off the HED rear wheel.
