Giro SLX Laces
Ok got a pair of Giro SLX, fantastic shoe for first time ever my feet are not going numb and aching.
Now to my problem how do i race with these things? Who has cut out tongue and put in different laces? Were did you cut the tongue out, how far down? What kinda of laces did you use?
_________________
Every Man Jack http://teamemj.com/ https://www.instagram.com/toothengineer/ https://www.strava.com/dashboard
Re: Giro SLX Laces [BBLOEHR] [ In reply to ]
Re: Giro SLX Laces [Thomas Gerlach] [ In reply to ]
Thomas Gerlach wrote:
Not to reinvent the wheel. This was my solution. Hope it helps.
Those feel comfy? Any issues?
_________________
I can't recall where, but I have seen somewhere a picture of a pair of Giro Empire ACC retro-fitted with Boa Closures. That might work.
But I am guessing that it's the Boa closures and other ratchet mechanisms that make some of these shoes more aerodynamically dirty.
Steve Fleck @stevefleck | Blog
Re: Giro SLX Laces [Fleck] [ In reply to ]
Boa will not work. You have to cut the tonque out of the shoes, that is a requirement for easy entry I have found. The Boa will cut your feet up.
Save: $20 on Air Relax Recovery Boots| $100 on Normatec| 15% on The Most Absorbable Magnesium | Best $50 Indoor Cycling Desk | NEW HED JET 6+
Wheelset - $1049 or less
Blogs: QUICK Air Relax Travel Case Review | Q2 Blood Test Results | Why Latex Bikes Tubes | Vittoria Corsa Speed Aero Data | Best Cheap Aero Sunglasses | 10 Reasons To Consider HED JET+
Boa will not work.
TG,
Scroll down a bit on this Weight Weenies forum thread:
http://weightweenies.starbike.com/...ewtopic.php?t=120572
This was not the pic/pair that I had seen a year or so ago, but popped up on a google search I just ran.
These are amazing. I have actually taken the heel tab off and the metal insert that the heel tab attaches to. The shoe is down to like 155grams and crazy comfy. With a broken foot, I can say the shoe is almost too stiff!!! I know of at least 4 other pros that have copied this setup, and at least a few other amateurs as well. I expect this setup to keep gaining steam. Another very notable pro is experimenting with the Sub6 and possibly some elastic laces as well. This was a little catch-22 for me. Part of me, wishes I kept this a secret, but that isn't like me, I like to share my passion.
Frankly, you have a shoe that is lighter, more aerodynamic, more comfy, and easier to get into and out of for T1/T2. I haven't experienced any downsides but it is going to take time and energy getting the elastic laces to the right tension for you.
Fleck wrote:
Boa will not work.
TG,
Sure boa like that will work, but I would suspect that there go your aerodynamics. The main reason I went with this shoe was that it was so much faster than my last shoe with straps. I guess we won't know without testing. But even like that the shoes won't be as easy to get into as the elastic. I had boa like that for many years on a variety of Specialized S-works, the tongue is going to want to sit flat. You may be able to slide your feet in but there are times where it is going to hurt you. The beauty of the elastic is you can just jam your foot in. The elastic will eventually find its way into the right place on your foot.
Great thanks for the advice, I have been wearing the giro for 4 weeks now making sure I liked it before I take the next step of cutting the tongue out, for me its kinda of scary to start cutting up a 300$+ shoe!
_________________
It hurt me to do it as, but with the elastic the tongue will just bunch up and you will immediately see you need to remove it in order for the elastic to work.
Ok so i did switch to fast laces, cut out the tongue, love the feel and fit. Question: how did you hide more of the laces? Mine don't look that "aero." Thanks!
_________________
That looks so bad.
I can give you 25% off Roka Sunglasses! Message me for details! Currently 1 code left! Code must be be redeemed by December 31!
Powered by All Out MultiSport - http://www.aomultisport.com/
I would assume you need to cut off all the extra laces then tuck them in the shoe or under the laces.
My Blog - Twitter - Instagram - JonnyO Coaching - EGO Tri Team - Greater Than Sports Drink
Re: Giro SLX Laces [jrielley] [ In reply to ]
I bought the laces on Thomas's blog and they will lie flat on the shoe. After I laced them up and rode a couple times with them I cut the laces and only have a little knot on the outside of the 2nd lace hole. They were too snug to get on/off easily laced up to the top hole and work just fine laced up to the 2nd hole. On/off easily now.
Re: Giro SLX Laces [1xatbandcamp] [ In reply to ]
can you post a picture up close just so i make sure i got it right before i start cutting laces?
_________________
Re: Giro SLX Laces [BryanD] [ In reply to ]
BryanD wrote:
That looks so bad.
this is why i am working on the problem to find a solution! But i guess there are still faster then you s-works tri shoe! Boom.
_________________
I don't have S-Works Trivents anymore
That might be fine as a training pair, but for races, yes I would ditch the extra lace. Not sure if you can see the picture at the bottom of this post. But you can see the ends are cut off and tied in a knot. The ends are also burnt with match. Over time as the laces stretch with use I end up making another knot and cutting off the first one. I do recommend the laces specifically in the post as well. They are an odd size, narrower, and go thru the eyelets and lay flat. Traditional flat elastic shoe laces are too wide and will end up bunching and will not lay flat.
Here is your solution: https://www.specialized.com/us/en/117539
They work great right out of the box and are more aero than anything not specifically created for the track.
Re: Giro SLX Laces [PubliusValerius] [ In reply to ]
Link is broken.
Re: Giro SLX Laces [Billyk24] [ In reply to ]
S-Works 6 road shoes. See how neat and clean:
this would mean the s-works worked with my foot, and it did not:-(
_________________
Thanks for sharing that Thomas, I had seen your post on the matter before but it has piqued my interest once again. Do you find that you miss the heeltab to hold your shoe when putting your foot in? I always thought this was one of the "essential" parts of a tri shoe, but then again most people run in "normal" running shoes with some kind of fast laces and those generally don't have heeltabs either (the tri specific running shoes do, of course)
That picture makes me sad for some reason. Such a beautiful shoe. It's like a nice car that has a sunroof installed with a chainsaw. But I guess, if it fits...
Re: Giro SLX Laces [Marlin] [ In reply to ]
I bet all of the "aero gains" from that shoe are lost with those laces.
