It could be much worse than gunk... the internal guide is known to detach within the frame on the mark 1 Exocet. It was shit even when it was connected properly, people couldn't use R2C front shifters etc because of the amount of slack that would have to be taken up.. basically you had to use friction shift on the FD for it to work at all. But then people had real problems when the internal noodle piece of crap guide or they used would detach at one or both ends. They engineered the problem out in the mark 2. Lots of reading on UK TT forums. Probably more threads if you search more thoroughly over there.
http://www.timetriallingforum.co.uk/...t-x-exocet-1-frames/ http://www.timetriallingforum.co.uk/...lanet-x-exocet-saga/ http://www.timetriallingforum.co.uk/...-front-mech-problem/ Wouldn't touch one, which I realize is not much help to you in your current position! If I ended up with one of these frames for some reason I'd try and thread Di2 through the frame somehow, or use ETAP... but if you have Di2 or ETAP you probably won't be riding an Exocet mark 1...!
You might be able to retrofit some outer stops at each end and run liner through the frame or something, or even full housing. Might need to get the drill out, a bit like the P3C modifications (thread
here), but I've never tried it on the PX frame.
Hope you can sort it out somehow.
