Troubleshooting Missing Running Dynamics on a Fitness Device
There are a number of possible causes for Running Dynamics to not appear as expected on your device. Please use the following guidelines to ensure that Running Dynamics will display on your device:
- Make sure your device is capable of displaying Running Dynamics information. Refer to the owner's manual to confirm that your device supports the Running Dynmics feature.
- Make sure you are using an HRM-Run 1st Gen., HRM-Run 2nd Gen., HRM-Tri, or Running Dynamics Pod. The HRM-Run modules have a silver "running man" icon on the front, and the HRM-Tri has silver "swimming man," "cycling man," "running man." Only HRM-Run and HRM-Tri modules measure and send out Running Dynamic information.
- Make sure your Heart Rate Monitor (HRM) is paired with your device. Please refer to the owner's manual for pairing instructions.
- If the device cannot find the HRM, or it finds it briefly and then the connection is lost, it could be that the battery on the HRM is low. Replace the battery in the HRM.
- If the device is paired, and you can see heart rate but not Running Dynamics, then it is most likely that the module is upside down1. To ensure that you are wearing the module in the correct orientation please confirm the following:
- The orientation of the Garmin logo on the module should match the orientation of the Garmin logo on the strap.
- The silver running logo should appear below the Garmin logo.
After ensuring the guidelines are met, you will see Running Dynamics on your device.
1If the HRM-Run/HRM-Tri is worn upside down, the device will be unable to track Pace and Distance when performing and Indoor Run activity. This will occur because the accelerometer data coming from the strap will take precedent over the accelerometer data from the watch.
