Bike Shops
Coaches
Fitters
Race Calendar
Running Stores
Store
Stack & Reach
Training Log
Triathlon Clubs
We Noticed
MAIN INDEX
RULES & LEGEND
LOG IN
Slowtwitch Forums
Garmin 500 custom mount
1
2
3
4
5
6
12
View All
Tri
Classifieds
Lavender
Jobs
Womens
Notices
Print Thread
simpy16
Mar 9, 12 1:55
Post #76 of 293
(19158 views)
Re: Garmin 500 custom mount [Tillquist]
In reply to
Quote
Reply
Anymore word on when the quarq garmin 500 mounts are going to be available?
nathanong87
Mar 9, 12 2:11
Post #77 of 293
(19154 views)
Re: Garmin 500 custom mount [hayai_240]
In reply to
Quote
Reply
here u go =)
hope this answers something
(This post was
edited
by nathanong87 on Mar 9, 12 5:59)
Joe Wurster
Mar 9, 12 13:29
Post #78 of 293
(19011 views)
Re: Garmin 500 custom mount [mahunc]
In reply to
Quote
Reply
X2
Woodie
Mar 9, 12 16:52
Post #79 of 293
(18954 views)
Re: Garmin 500 custom mount [Joe Wurster]
In reply to
Quote
Reply
Just to keep you all up to date... I've been getting a bunch of emails from this posting. Below is a link for pre-order. We're planning on being able to start shipping parts in 3 weeks.
http://www.abovecategorycycling.com/...omputers-mounts.html
Best,
Woody
MattAune
Mar 9, 12 18:41
Post #80 of 293
(18917 views)
Re: Garmin 500 custom mount [Woodie]
In reply to
Quote
Reply
From looking at the pictures of your mount, it appears that I am going to have to untapped my bars and remove on set of shifters for the install. Is tha a true statement? Is there a reason you didn't use 2 screws similar to how the bars and stem bolt together?
Woodie
Mar 9, 12 20:41
Post #81 of 293
(18888 views)
Re: Garmin 500 custom mount [MattAune]
In reply to
Quote
Reply
The Bar Fly is made to stretch around the diameter of the bar. You will not have to unwrap your bars or remove your shifter. That factor was a must in designing this part... The reason I didn't go with two bolts was simple: it doesn't look as good or purpose built. I really wanted something that would blend in and compliment a bicycle.
Woody
In Reply To:
In Reply To:
DClarke
Mar 9, 12 22:20
Post #82 of 293
(18852 views)
In reply to
Quote
Reply
Does it work on a one piece bar stem combo? They seem to have even larger bad diameter.
Duncan
nebmot
Mar 10, 12 17:49
Post #83 of 293
(18694 views)
In reply to
Quote
Reply
Is the quarq one going to fit the 800 as well?
ishi no ue ni san nen
| Perseverance will win in the end. |
Blog
@nebmot
| Guided by
MarkyV
Strava
grosso27
Mar 10, 12 20:20
Post #84 of 293
(18653 views)
Re: Garmin 500 custom mount [nebmot]
In reply to
Quote
Reply
i don't understand why you guys are going through all this trouble. doesn't the FSA control center mount do exactly what you're looking for?
granted, it doesn't have the built-in 1/4 turn mount, it give you two pivot points, so you can mount the Edge flush with your bars.
Also, ran across this, thought it was interesting, if for nothing other than design ideas:
http://www.ebay.com/itm/25g-Carbon-Bike-Stem-Speedometer-Bracket-Computer-mount-/251010977240?pt=LH_DefaultDomain_0&hash=item3a716b8dd8#ht_9413wt_1202
Wattie Ink Elite Team
K-Swiss
Scott
PowerBar
BlueSeventy
FuelBelt
Kask Helmets
ISM Saddles
Speedfil
Reynolds
Rev3
beston
Mar 11, 12 18:52
Post #85 of 293
(18512 views)
Re: Garmin 500 custom mount [jeffmpollock]
In reply to
Quote
Reply
Thanks for this. It inspired me to try my own version to mount in between my aerobars. I must admit that I don't know much about working with metal and have no idea how to source aluminum of the appropriate thickness. So, I took my son to home depot and we started looking through any materials that had the correct 1/16th thickness (I brought my calipers with me). I ended up buying a 10' strip of plastic from the windows and doors section for $10.
The end product may not look great, but I can certainly say that it functions well! The Garmin fits snug in there and is not about to swivel back and forth.
thanks for posting your solution!
jeffmpollock
Mar 11, 12 19:15
Post #86 of 293
(19887 views)
Re: Garmin 500 custom mount [beston]
In reply to
Quote
Reply
Nice! I ended up making one for my TT bike, but I made it cross at the top of the aerobar extensions and then used electrical tape to secure it down to each extension. Works like a charm and a little cleaner than the zipp ties. If you make a 2nd one you could try that, just rotate what you did 90 degrees and make sure the cutouts are in the right spot. Well done!
wildworks99
Mar 12, 12 12:34
Post #87 of 293
(19719 views)
Re: Garmin 500 custom mount [steepcreek]
In reply to
Quote
Reply
Great idea for the TT bars with the PVC !! cheap and easy.... nice work!
ComidaDeluxe
Mar 12, 12 13:38
Post #88 of 293
(19682 views)
Re: Garmin 500 custom mount [wildworks99]
In reply to
Quote
Reply
I was inspired by the guy's with the spoke and the nail. I wanted my mount up near the shifters so I could see it without moving my head down,and also because I have poor near vision and need it a little further out when I'm aero. I tried a knob extension from the LBS but it looked bulky and I also didn't want anything to interfere with my hand placement, I tend to move my hands around a bit from a normal grip to rolling my hands down the the sides of the extensions or occasionally clasping my hands together above them. I didn't want to lose any of my available hand placement spots.
I made mine without the nail and without the loop. By not making a loop the spoke extended further back along the bars and so I think it's plenty secure. Being a real man and all, I only had one option for securing the spoke ends to the bars... Duct tape. The spoke ends go back almost the length that I taped. I was going to use 2 tiny zip ties under the tape like the other guy did but I didn't have any so I stuck a couple of tight little rubber bands instead. In retrospect I think it would have been just fine without them. I knocked it around a good bit and it's plenty secure. The mount wiggle just a bit on it's own but once computer is on there it is rock steady. Mine is for a 310xt, but it's the same quick release mount for a 500 I think. If you've read this far, I'll expect a paypal of $9.99 sent for the proprietary info....
%FTP
Mar 13, 12 6:04
Post #89 of 293
(19566 views)
In reply to
Quote
Reply
Jeff, where did you find this type of aluminum? I've been looking in a bunch of different hardware stores/home depot etc and can't find anything flat strips in 1/16th inch. Everything I've seen is angle iron. Any tips on where to find something like this?
jeffmpollock
Mar 13, 12 7:46
Post #90 of 293
(19536 views)
Re: Garmin 500 custom mount [%FTP]
In reply to
Quote
Reply
Got mine at lowes. Also found at A-boy. Could likely find online. Should be 1/16 thick, about 1.5 in wide. Good luck!
BigBloke
Mar 13, 12 8:14
Post #91 of 293
(19523 views)
Re: Garmin 500 custom mount [ComidaDeluxe]
In reply to
Quote
Reply
ComidaDeluxe -
Have you actually tried that setup on the road? I started with something similar before migrating to the method shown below because if your roads are anything like the ones here in NJ, surely that thing's gonna bounce around like crazy due to the weight of the Garmin 500.
Using the method below (which my friends refer to as a "Clark Mount") with a thick spoke (14 gauge, not what you'll find on expensive wheels) if's very stable on the bumpiest of roads.
Doug
www.triathlonlog.com
Edit: typo
(This post was
edited
by BigBloke on Mar 14, 12 6:21)
415brian
Mar 13, 12 12:52
Post #92 of 293
(19458 views)
In reply to
Quote
Reply
great DIY solution! i'd like to replicate.
if i wanted to find the same plastics at home depot, any guidance on what i'd ask for, e.g. product name or application purpose?
beston
Mar 13, 12 12:57
Post #93 of 293
(19450 views)
Re: Garmin 500 custom mount [415brian]
In reply to
Quote
Reply
I won't be home until later tonight, but I will get out the receipt and see If I can get an actual product number / description for you.
It was in the screen door section...
beston
Mar 13, 12 22:04
Post #94 of 293
(19360 views)
In reply to
Quote
Reply
Here's a little more information on the plastic I purchased from Home Depot.
•731677350005 Porch Screen Base 3 1/2"
•The price was $10.45 for 10'
Although the product is made in the USA, I bought it in Canada. I don't know if there would be differences with what's available in the US. I've attached a picture of the actual piece so you can get an idea of what to look for.
415brian
Mar 13, 12 22:05
Post #95 of 293
(19358 views)
In reply to
Quote
Reply
perfect - thanks!
ComidaDeluxe
Mar 13, 12 22:46
Post #96 of 293
(19337 views)
Re: Garmin 500 custom mount [BigBloke]
In reply to
Quote
Reply
It's road tested and holds steady with a 310. I've never used a 500, but it's bigger than a 310, not sure about the weight difference. Angling it up helped but mainly I think it's the fact that I have more of the spoke secured straight to the bar than I have exposed. There's a good 3-4 inches of spoke extending along the bars under the tape.
ccassidy
Mar 14, 12 15:53
Post #97 of 293
(19212 views)
In reply to
Quote
Reply
Beston - where do your hands go...........
beston
Mar 14, 12 19:31
Post #98 of 293
(19158 views)
Re: Garmin 500 custom mount [ccassidy]
In reply to
Quote
Reply
I have moved the mount back an inch or so, but the mount still covers about half of the grip.
When normally riding, my hands feel most comfortable when gripping the shifter body (the lever sits between my fingers) and I never seem to hold much of the grip anyway.
Having said that, I haven't ridden the bike since putting on the mount, so I can't yet confirm that this is the best position for me.
simpy16
Mar 14, 12 20:44
Post #99 of 293
(19139 views)
Re: Garmin 500 custom mount [drgwood]
In reply to
Quote
Reply
I emailed Quarq and heard that the Lopro 500 mount is scheduled to be released in May 2012.
I think it may be just close enough that I will wait to see more about it and price before I buy another option.
Having it on the stem is ok for now, but i can see where in front of the handlebars would be pretty amazing.
simpy16
Mar 14, 12 20:53
Post #100 of 293
(19130 views)
In reply to
Quote
Reply
Woodie,
Have you thought about making the Bar fly in a TT version that would mount via a screw clasp off of one of the extensions and then turn 90 degrees so that the face of the 500 would sit in-between the aerobars?
I currently have the profile design "bar" that tightens itself to the clip wrapped around the extension but after riding for a some time I find that bracket can start to rotate and get loose.
I am very interested in your Bar fly but would really love a TT version for my Speed Concept as I don't have a great way to mount it right now.
1
2
3
4
5
6
12
View All
Print Thread
this forum
this category
all forums
All words
Any words
Whole Phrase
Cycling shoe footbeds
Do you have or are you considering custom cycling shoe footbeds?
Don't have, don't see the value
Don't have, might want
Do have, me likey
Tried them, didn't help
Haven't thought about it
