Newbie here, I did a GURU bike fit here locally and I was under the impression it would be easy to figure all appropriate bikes that would fit. I was recomended 2 bikes that they sell, which is cool and I understand but I thought I could easily determine if other bikes would work also. If I had some of this data could someone tell me if a bike would work with me or not? Or even better, an effective range of stack and reach if possible? Thanks a lot!
SX: 127
SY: 673
HX: 489
HY:645
Saddle Height over bottom bracket: 737mm
Saddle Setback: 2mm
Drop from saddle to bars: 21mm
Reach from saddle to bars: 806mm
Equipment Info
Saddle Thickness: 53mm
Saddle clamp to nose: 125mm
Bar length: 315mm
Pad stack height: 60mm
Crank length: 170mm
I was recomended Felt B series
Stem length: 110mm
Stem angle: +6
Spacers: 50mm
Frame Reach: 405mm
Frame Stack: 535mm
Measuring myself I got 5'8" and 31.5" inseam
Going off of Slowtwich's DB
2011 Slice: 54cm Stack 50.9 Reach 39.8
researched these 0n my own ... ie could be wrong
2009 Cervelo P1 54cm: stack 512 reach 418
2008 Felt S32 54cm going off 2011 DB Stack 510 reach 415
Thanks so much!
SX: 127
SY: 673
HX: 489
HY:645
Saddle Setback: 2mm
Equipment Info
Bar length: 315mm
Crank length: 170mm
Stem length: 110mm
Stem angle: +6
Spacers: 50mm
Frame Reach: 405mm
Frame Stack: 535mm
54
50.9
39.8
Thanks so much!
54
50.9
39.8
