swim_corey_run wrote:
Which one do you think is the most beneficial for triathlon?
Plus what are some other exercises you incorporate into a strength routine?
both are good, but work slightly different muscle sets;
Front: emphasizes more the quads and upper back due to the more upright posture. It minimizes loading on the lumbar spine and forces increased core stabalization. Front squat also requires better flexibility to perform properly, specifically within the range of motion of shoulders. Safer if doing alone as can dump weight easily.
Back: emphasizes the glutes (all) and lumbar spine. Because you are using bigger muscles and really activating your glutes you can lift more (either by rep or by weight) from the back. The simple placement of the bar is also more conducive to heavier weight as well rather than resting on the collarbone.
Neither is better than the other, it really depends what you are trying to work. Both are going to hit quads, ankle, knee and hip.
In the off-season i really focus on building leg strength, though if you spend any time over on the wattage google forum there's a fair bit saying strength training is negligible for building bike speed. I do it because i don't just ride bikes on road, and I like lifting heavy things and putting them down again.
Few workouts - not all to be done in same workout, just examples
5x5 squat heavy either front or back
5x10 squat lighter but hold in the hole for 5s before exploding up
box jumps
back squat walking lunges 25m
deadlifts 5x5
