Had my 920XT for a week now and am so close to being completely smitten.
However I do have issues with the connection to GCM on my Android (4.4.4 on an Xperia Z1 Compact)
I use it as a Daily Tracker and noticed that I am getting frequent (x times per day) crashes in the sync .. seems to get half way through and then just crashes/stalls (although the app remains running) which means the steps aren't syncing. I need to remove the device and readd to get the syning back
The worst thing though is that several times a day I go out of range of the phone. When I do, the connection is lost and the only way I can get it to re-establish the connection is through re-pairing using the pin.
If it was a 'click here to reconnect' button it would be fine.. but the whole thing means I need to ..
a. pull down the notifications bar from the top and click on the Yes to connect request (when the phone spots a request)
b. pull down the notification bar from the top again and this time go through the re-pairing process by entering the pin showing on the watch.
It is seriously taking away from my 920XT experience
Things to note
1. I am a long term Garmin user and have used GCM/bluetooth with my Edge 810, Vivofit and FR620 (the 620 could be fussy and not always connect, but usually worked)
2. I have tried the usual..
Turn on turn off Bluetooth
Turn on turn off phone
Remove device and re-pair
Uninstall and reinstall GCM
Are there any other 920XT Android users.. and are you experiencing the same nightsweats of losing the connection?
(doesn't seem to be so much of an issue for iPhone users)
