RowToTri wrote:
Thanks for the explanation! Filament winding of tube shapes seems very straightforward, but wheels seem much more complicated. Would you mind answering a few questions?
How do you wind onto a wheel? I would think that the wheel would have to pass through the fiber every revolution. I assume the wheels are not made in two halves and joined together after.
How do you get highly variable wall thicknesses, such as the inner diameter and tire side of the rim vs. the sides?
How do you get the fibers to conform to convex shapes along the mandrel without a secondary molding process?
Sorry - that's a lot of questions, but I'm interested in the process.
Good questions, and unfortunately I cannot tell you the details as already even what details we release end up adorning other companies' websites and product lines.
But, I can tell you the following, winding toruses is not theoretically that complicated. This is how electronic toroidal inductors are made:
https://www.youtube.com/watch?v=82PpCzM2CUg Some factories in China use a similar process to wind rims, but this results in fiber alignment geometry problems as unlike in that example of a square profile torroidal transformer core in the video, they are winding a curved rim. Thus the carbon tape that they are winding also ends up curved and fanned - you get higher density of fibers at the inner section of the rim, versus the outer section of the rim and this problem gets worse for deeper rims. The curvature of the fibers is visible thus the structure (rim) that is made using a simple torus winding process has very poor mechanical properties. Only a straight fiber is a strong and stiff fiber. Curved fibers are a defect.
This is why we made a big deal of being able to make a 50.7mm rim and still retain our fiber alignments and geometry.
There is a secondary molding process to set the final shape and get a good surface finish, but this step cannot correct incorrect fiber placement, it only sets the final shape of the rim.
Here is a presentation I gave at Cyclitech 2015 in Brussels. It shows you the rim cross section:
https://my.visme.co/...-presentation-515ad6 The rim body is filament wound, tire bed is separately wrapped (soon filament wound too) and the spoke hole reinforcement section is manually laid up and then the whole thing is co cured. We are working on the process continually towards achieving full automation, while not resorting to a crimp based process.
Venn Carbon Wheels
Velocite Bikes
