JASpencer wrote:
Surely I can't be the only one who has a hard time buying that the problem was magically solved by cleaning the steerer tube? If that's the case, I could/should have experienced several catastrophic crashes, yet have NEVER experienced this issue.
This I can understand, but since it is just a matter of stem-on-fork clamping issue I also have a hard time in getting that several stems, at least 3 forks if I read it correctly and none of the several stem / fork combinations seem to have worked. Which I find hard to get since I got my Andean just after Kiley wrote his first initial review were he mentioned this issue for the first time so i think we have had the same type of frame/fork. No updates or something done on them. It was him that set me on the right track to shave of a few mm from the pinching bolt to get the stem clamped tight as hell on the steerer column. And he was spot on, because with the extra few mm on the pinching bolt I couldn't get it tight. But the few mm shaved of solved the issue completely.
Since I f*ckd up one stem by trying to be creative with it, I received another and this had also no issues with that second stem. And you bet that those first few weeks of riding I stopped several times to re-check and double check play on the head set or movement of the stem and bars due to Kiley's initial review. I rode with my Torque wrench at hand to see if the pinch bolt would come loose, if there was play in the headset or in the cap and bolt on top of the stem.
It was just after 2 months that I have had enough 'faith' that everything was secure that I put the hard top box on top of the stem. What ever I did, after rebuilding it several times, the stem never came loose, the bars were as tight as they could be, I hit some nasty bumps and potholes. Nothing that could replicate the issue that Kiley had (other then that ultra super tight bb he also mentioned)
Which makes me wonder what it could have been that several stems, 3 different forks not could solve and as far as i read happened to no one else that ownes a DB Andean. Not saying that it didn't happen with Kiley's bike, but how small are the changes that he got 3 forks that were off in diameter and/or got several stems that all didn't work. Or did he and/or the mechanic did something on all those forks/stem/builts over and over again that made the same issue repeat itself.
Maybe a standard way, a routine if you would like, on how some parts were greased, lubed or whatever that on a different bike's stem/fork combo don't matter but just with this specific set created the issue and thus it kept coming back.
Not accusing anyone, just really curious since I own an Andean.
Jeroen
