tridork wrote:
It seems like you've isolated the cause of your wobble. That's great.
From my experience, something, (and there are lots of possible causes) starts an oscillation of some sort. This creates a nervous rider and that invariably leads to hanging on tighter. This generally makes the problem worse. When I ride downhill, I virtually don't hold on at all. My hands barely rest on the bars. I've hit some fairly large objects and never actually come off. Holding on tight makes the problem worse believe.
That said, since you've pretty much found the cause of your wheel issue, don't simply stop using that wheel, see what you can change to make the wheel usable again.
Others have suggested, but I'll re-iterate.
Valve weight can be enough to initiate a vibration. Use the shortest, lightest valve you can get away with.Take off the screw on thingy that keeps the valve tight in the hole (assuming you're using it).
Check wheel magnet location. Regardless of where it is, try it in other places. Trial and error will find a sweet spot.
Assuming clincher tires, make sure they're seated properly. I see quite a few people with incorrectly seated tires that in effect, create a hump on one side of the wheel.
Tires? flip them around, to relocate a possible heavy point of the tire. Same with a tube? Use a different (lighter?) tire. Powder your tubes and inside of the tire, so your tube and tire seat properly. Back in the day I didn't do this and once had a lump in my tire from a tube with a small fold! (yes I was in a hurry when I was installing it). Now I powder my tubes so they slide into the perfect position easier.
Wheel. Check the wheel itself. Is it straight and trued? Get it professionally tested. I had some HED3's and while they were within factory spec, the rear had a slight wobble built in it. It didn't cause me an issue, but I could feel it when going fast. Of course, with a HED3, there is no truing possible, but most wheels can be trued. Spin the wheel in a wheel jig to see if the wheel is out of balance.
Check wheel bearings are at the correct tightness. Even a slight looseness can start a vibration.
Finding a wheel imbalance fault can almost as hard as finding a squeak in ones bike. Annoyingly, just about every squeak in a bike sounds like its coming from the BB! Rarely does the squeak ever come from the BB :-)
Most of the things you have mentioned there won't make one iota of difference if there is a true speed wobble.
Wheel bearings and valves pale into insignificance in the face of a proper oscillation.
Changing stack height usually works by changing the flex variables on the steerer and any wheel culprits are usually weight orientated or a change of tyre height changing the trail.
I have seen one bike where even a change of fork didn't cure it, and I would suspect in that case that it is a frame stiffness/damping issue.
Most people that say they have experienced speed wobble haven't and when they do get a chance to ride a problem bike will be amazed at the forces involved and it doesn't matter what you do, relax, dramatically change position, clamp the top tube with your knees etc, you simply cannot stop it.
An incorrectly fitted tyre is usually not noticed by a rider unless they can see a front tyre wobbling in front of their eyes.
Just the fact that the bike is in motion is enough to set off a wobble if it is inclined to do so.
Leave the screw on thingy on there, it will stop latex tubes from creaping around the valve stem and dying.
