On my edge 500, I manually changed my power reading to include zeros. I cannot locate that option on my 920. Does the 920 not offer that option? If not, does it default to include zeros in power? I read a couple of threads on the Garmin forum and those were inconclusive.
Re: Do you know if zeros avg for Power on 920t [NeverEnough]
Should be easy enough to figure out. Go out for 1 minute and bike then coast for 30 seconds. If your avg power falls significantly than it is including zeros.
Re: Do you know if zeros avg for Power on 920t [Thomas Gerlach]
Thanks....unfortunately I am sitting at work and trying to figure out if you can change the setting to not include zeros. If i test it later and it isn't, can/how do i change it?
You still out for Raleigh?
You could look at a power file and see if there is any time at zero watts.
I would just use normalized power then and I am in for Raleigh 70.3 this weekend. Not 100% healed from Knoxville but good enough for me.
Found someones file...looks like the default is set to include zeros.
Thomas...check your PM shortly.
fwiw....on my edge, I went back to 2 rides. One where I had zeros included, one where I did not....both show zero's included in Garmin Connect.
NeverEnough wrote:
On my edge 500, I manually changed my power reading to include zeros. I cannot locate that option on my 920. Does the 920 not offer that option? If not, does it default to include zeros in power? I read a couple of threads on the Garmin forum and those were inconclusive.RTFM :) http://static.garmincdn.com/...nner_920XT_OM_EN.pdf
Rodney
TrainingPeaks | Altra Running | RAD Roller
http://www.goinglong.ca
rbuike wrote:
AFDT
