Converting downtube shifter frame to bar-ends
I recently purchased a frame that is built for the old down-tube shifters. It has these ugly little tubes sticking out the side and I want to use bar-end shifters. When I have this bike built for me how will the cables be routed around these little tubes? Can I remove the little tubes? Most bikes I see today have a small grove to run the cables through that looks very clean, but not this one, it has those ugly little tubes.
Thanks,
Dave from VA
Re: Converting downtube shifter frame to bar-ends [DC Pattie] [ In reply to ]
There are some little "tits" that screw onto those ugly little tubes, that accept the end of the cable housing that runs from the bar end shifter. Still looks ugly and has exposed cables, but it works. If you want internal or recessed cable routing, you gotta buy a new frame.
