jackmott wrote:
I tend to avoid road bikes with chainstay brakes, though it wouldn't be a total deal breaker, reason being that it is so common you check to make sure brakes are adjusted well before a ride and I Don't want to have to flip the bike over to make adjustments or see how close they are. Also problematic if you grab a neutral wheel in a race.
The aero benefit seems to be so small, I'm guessing, ~2 to ~3 seconds per 40k at best? That not worth it on a road bike.
SuperDave wrote:
NordicSkier wrote:
I refuse to buy a road bike with chainstay mounted brakes.
Can you elaborate on why you've reached that conclusion? Are you also going to avoid disc brakes?
-SD
How often have you checked your brakes and they've needed immediate attention that wouldn't have been revealed by grabbing the lever or just spinning the wheel and verifying function non-visually?
How often do you adjust the brakes without the bike in a repair stand?
2-3w @50kph seems a reasonable estimate but the advantages are beyond the aerodynamic boost. There are structural requirements to mounting calipers that can be eliminated on the seat stays but do not need to be added to the chainstays because they already handle the bulk of the drivetrain loads.
As for the wheel rub, if you think about the deflection of the wheel as a result of twist a chainstay brake is more susceptible to this lack of wheel and frame stiffness because the chain tension is trying to pull the wheel forward on the drive side causing the deflection perpendicular to the vector to be greater the farther away from the chain/cassette. A caliper on the seat stays is closer to this axis so the deflection is less.
-SD
https://www.kickstarter.com/...bike-for-the-new-era
