Hey all,
So here's a weird one. My chain is misaligned when spinning backwards...
Not sure how much video makes it obvious, but the chain is a little more outward then the teeth, so it first get's caught by the tooth, then it pulls the chain inwards which results in a loud click. When spinning backwards, this results in ugly grinding noises...
Not sure how to fix this one... the rear derailleur cable tension should adjust where the chain lands when spinning in the normal direction, but what does one do when you have the problem in reverse? It's as if my front cranksets are not aligned properly?
Not sure how to tackle this, any ideas?
(the clicking noise appears when chain is straight, i.e. middle-to-small cogs in the middle large in front. Bike is two months old so cannot be chain wear. Chain is clean... running out of options here...)
Edit: Looking further into the cranks, I see a large-ish gap on the left hand side crank which exposes a curved washer between the crank and the frame. Attaching some pics to the post. Is this normal?
