Setting it up to run bare cable to Omega X. Question to ST - do you use a ferrule there or just cut the housing to make contact with the stop? The housing does have to make a pretty sharp turn to fit into the cable stop inside the stem - do you feel that compromises the braking power in any way?
It would be awesome to see some pics of your setup if possible. Thank you in advance.
Next races on the schedule: none at the moment
