Bike fit critique
Hi all. Feel free to comment/abuse/shame/admire my DIY fitting job. Or my bike, my loungeroom, whatever floats your boat.
Me: 70kg, 185 cm, Saddle height 780 mm, 42 yo white suburban male
ISM Attack saddle
20mm offset reversed seatpost
110 x 35° stem (upside down)
PD Viper Wing Base bar
3T Clip On aero bars
I will probably only do shorter races (sprints mostly).
Sorry for the black-on-black (from both a fashion and visual perspective)
Re: Bike fit critique [MattyK] [ In reply to ]
mechanically sound. you could go more aggresive in many ways. You need your helmet on and show how well you can tuck your head. What are your goals?
i like it, mattyk. you did a nice job. others might find something worth critiquing but i don't see anything really necessary of fixing. you look like clark kent and when you take off your glasses you become chris froome.
Dan Empfield
aka Slowman
But you did not pay to get a "professional" bike fit. Shame on you. :)
Dave Campbell | Facebook | @DaveECampbell | h2ofun@h2ofun.net
Boom Nutrition code 19F4Y3 $5 off 24 pack box | Bionic Runner | PowerCranks | Velotron | Spruzzamist
Lions don't lose sleep worrying about the sheep
Re: Bike fit critique [Rider17] [ In reply to ]
My main goal is to beat my work mates who have 10-15 years of youth on me :D and stay injury free (mostly from running).
There's a 10mm spacer under the stem, and a 20mm cone under that, so the front end could come down more. I might do that progressively...
Currently have a road helmet (Lazer Blade) so unless I find a bargain it's a bit of a brick, but at least it's rounded off on the tail a little.
Re: Bike fit critique [Slowman] [ In reply to ]
Thanks.
I definitely have Froomey's arms! And I like looking at my stem.
Dan is right (of course). You look solid. As far as minimizing frontal area you got it again. Do it slowly. Focus on turtling your head with your helmet. This is very important
I'm not sure I'd bring you down more, as I think you're just starting to tip towards over-arching your back. But you're looking ok, pedaling very smooth with little body rocking. Nothing jumping out as a problem.
To unbrick your helmet, use packing tape to cover the vents. Go front to back with a little overlap. Probably 80% of the solution for $.10 worth of tape. Some of the domed skateboard helmets also do pretty well and tend to be cheap ($20-30). G-luck -J
Life is tough. But it's tougher when you're stupid. -John Wayne
Crank length?
Biomechanically you look pretty good. But...and there's always a but on ST.
- Kyleyay is right in asking about crank length. Your cranks are probably a bit long considering they're on a road bike with tri bars.
- You could have a bit more reach but you're in the range - you can do this by comfort.
- Bike fit is all about saddle comfort and getting the hips open. Saddle looks good. Hips have some movement (refer back to crank length to help out here).
- Don't worry about the helmet. You don't do a bike fit to a helmet.
Re: Bike fit critique [kileyay] [ In reply to ]
kileyay wrote:
Crank length?
175
Re: Bike fit critique [PennBen] [ In reply to ]
So why do you say his cranks are too long? Any power data to back this statement up?
Re: Bike fit critique [h2ofun] [ In reply to ]
Yes. There is quite a bit of research on this. You can google it and you'll get info there - from fitters to pro teams. You can go to google scholar and get peer reviewed info there. If you want something quick and accessible 51 Speedshop has posted on this. Lots of good information out there and 100s of fits in my own experience.
The other thing - more than sheer watts - is pedal efficiency. On a tri fit you want good, efficient circular motion. Yes, road bike too, but we're on a tri bike at the moment. So you want to clear space at the top of the pedal stroke to get up and over and make power on the downstroke. Most peoples hips are off. Again, most people's hips are off. So shortening the crank length - say 1 cm - gives us a cm at the top of the pedal stroke because you offset seat height to accommodate the change - e.g cranks get closer on the down and further away in the up strike. We say in the studio - quiet hips are fast. There's a lot more to it but some of this only becomes clear in practice. Pm me if you want - as they say in the south - the down the road about this.
