I need to replace my BB and it is not threaded. Does anyone have a favorite bearing press tool?
Re: Bearing Press Tool [ironcode]
ironcode wrote:
I need to replace my BB and it is not threaded. Does anyone have a favorite bearing press tool?I've been using one of these for a few years, and it does the trick, works well for wheel hub bearings too:
https://www.bocabearings.com/parts/Bearing-Tool
That said, if you don't mind spending the money, I'd get one of these..
http://www.jensonusa.com/...;q=bbp-1&l=bbp-1
I just made a quick one with a by cutting two pieces of scrap wood, drilling a hole, and placing a threaded rod through. Put a nut and washer on both sides and tighten
A link from another thread ..
___/\___/\___/\___ the s u r f b o a r d of the K u r p f a l z is the r o a d b i k e .. oSo >>
Re: Bearing Press Tool [sausskross]
Thanks, this is a great resource.
That Park tool bearing press is interesting. I hadn't see that one before. When I put the threaded adapter on my BB-30 frameset a couple of years ago, I used their headset press -- HHP-2. Also a very nice piece of hardware. Overkill perhaps but quite nice
http://www.parktool.com/product/bearing-cup-press-hhp-2
Re: Bearing Press Tool [JoeO]
Be careful ..
Yikes. Glad I wasn't putting in bearings. That would have sucked.
It may depend on which BB you have.
You can use a BB30 drift set for a couple different systems like BB30, PF30, BBright
You will need two things.. a press and the drifts. I use the Wheels Manufacturing press and have some Park Tools drifts... Wheels Manufacturing makes a set of multi drifts that would work well if you don't have the drifts.
https://www.amazon.com/TOOL-BEARING-WOB-UNIVERSAL-PRESS/dp/B01MU3K0I1/ref=sr_1_12?ie=UTF8&qid=1487081423&sr=8-12&keywords=wheels+manufacturing+press
Re: Bearing Press Tool [xeon]
Thanks for the link, this is my first time doing this work so I need both tools.
Someone above mentioned wheels manufacturing. They make good stuff, I just got there lower end bearing press which was like $30, not too expensive even if you don't plan on pressing bearings that often. They also sell all sorts of individual drifts for <$10/each. It's really not that hard to press bearings, if you are at all mechanically inclined, so it's probably worth the investment.
Here's the webpage with all their bearing press stuff:
http://wheelsmfg.com/...sses-extractors.html
They also sell just about every replacement bearing you would ever need
ETA: website info
ETA: website info
I have that set plus a set of park BB30 drifts
Re: Bearing Press Tool [jsoderman]
jsoderman wrote:
Someone above mentioned wheels manufacturing. They make good stuff, I just got there lower end bearing press which was like $30, not too expensive even if you don't plan on pressing bearings that often. They also sell all sorts of individual drifts for <$10/each. It's really not that hard to press bearings, if you are at all mechanically inclined, so it's probably worth the investment. Here's the webpage with all their bearing press stuff:
ETA: website info
ironcode wrote:
I need to replace my BB and it is not threaded. Does anyone have a favorite bearing press tool?How often do you change BBs? Take to the LBS, $10 you are done.
It's the last thing I want to learn.
