It's not really meant to compare one workout to another. An hour a 6:45 today will net you the same number as an hour at 6:45 6 months from now (unless your threshold pace has changed)
TSS is about quantifying load over time which is tracked in the Performance Management Chart -
http://home.trainingpeaks.com/...nce-management-chart Quote:
TSS, which is modeled after Dr. Eric Bannister's heart rate-based training impulse (TRIMPS), takes into account both the intensity (i.e., IF) and the duration of each training session, and might be best viewed as a predictor of the amount of glycogen utilized in each workout. Thus, a very high TSS resulting from a single race or training session can be used an indicator that one or more days should be scheduled. While individuals will tend to differ in how much training they can tolerate, depending on their training background, natural abilities, etc., the following scale can be used as an approximate guide:
- TSS less than 150 - low (recovery generally complete by following day)
- 150-300 - medium (some residual fatigue may be present the next day, but gone by 2nd day)
- 300-450 - high (some residual fatigue may be present even after 2 days)
- Greater than 450 - very high (residual fatigue lasting several days likely)
As well, the cumulative TSS per week or per month can be used help identify the maximum intensity and volume of training that still leads to improvements, rather than overtraining.
Rodney
TrainingPeaks | Altra Running | RAD Roller
http://www.goinglong.ca
