Hi. I was inquiring how your surgery went? How did the doctor make the incision? Did he go in from the bottom?
My sesamoid bones are enlarged in both of my feet, because I was wearing a pair of skate shoes (skateboarders wear these shoes, but I don't ride a skate board) and the shoe was putting pressure on the top of my big toes, in just the right spot, to induce my sesamoid bones to enlarge in both feet (I think this was done maliciously) and I only the wore the shoes twice. Now, I have a really bad imbalance on the bottom of both my feet, but more so on the right and it is so crazy how this happened to me. I haven't found a sports surgeon to correct this problem and it changed the silhouette of both of my feet, not for the best. As a result, both of my big toes, but worse on the right, are veering in the wrong direction, causing my second toe to bend uncomfortably in an outward direction, in both feet. My big toes are not setting on the ground straight forward. My right big toe is veering to the right, causing the bone on the side of my big toe to push out and it hurts. I'm enduring the same thing on my other foot. This cold weather is making it worse. The joint bone on the baby toe of both of my feet, has new extra bone growth, because of this imbalance on the bottom of my feet, contributing to the change in the silhouette of my foot, along with how my big toes are veering off in the wrong direction. I bought the shoes at Payless and I have never had a problem with Payless shoes. It's really insane!
Are you back on your feet again? I use to do a lot of long-distance running and I never had a problem with sesamoiditis. I never heard of sesamoiditis, until this happened to me and I can't believe I developed this from a pair of shoes.
I have another question. Did anything change with your biochemistry, as a result of your injury? My entire stance changed and now the top of my hands are facing forward, when I stand comfortably, instead of at my side-the way they should be and my pelvis changed direction, too. My ankles use to be in straight alignment and now they roll inward. You won't believe this, but my hair changed texture, my eyes changed shape and my upper jaw was affected by my new stance. Your sesamoid bones should be the size of a kernel of corn, not a popped corn or hard marble.
