jonahsdad wrote:
Any devices out there that actually work and are small enough to run with?
Thanks
I used to run with a Sirius Stiletto 100 before I switched over to using the SiriusXm app. Are you in a place with no cell coverage? I went through two of those things. The battery life on them is a bit bad due to the amps the unit needs to draw to pull down a good signal. It worked pretty well till my dog tripped me then I smashed it on the ground. I don't know if they are still made but they can be found on eBay.
