I've tried searching pretty much everywhere, no success so I've come here. I want to get my arm pads LOWER (slammed) on my brezza basebar but can't find any solution and don't want to swap stems (TriRig Sigma). Has anyone direct mounted the armrests to the bar and mounted the extensions on the underside? Here is the lowest I can get, looking to go all the way down.
Because the risers 'cradle' the extensions, removing them is going to introduce instability that will fatigue the mounting bolts. While not totally slammed, I would suggest you take those risers to a machine shop and have them cut down to where there is 1mm left and then get appropriate length bolts to mount them.
¯\_(ツ)_/¯
¯\_(ツ)_/¯
