Cajer wrote:
It's residue from the pad, and I've heard from some sources that the pad will melt onto the rim during prolonged braking.
Another possible way for these pads to dissipate heat is to ablate away the pad material, which is why you see super fast wear on some newer pads like the Zipp Platinum and the Swiss Stop Black Prince. Judging from what I've heard about the good durability of yellow swiss stop pads, they do not seem to do this. So that could be a contributing factor to why swiss stop says run hotter than the newer Black Prince.
I guess you have to look at your use case. The Bonetrager engineers need to make recommendations based on say a 200 lb guy descending Alpe d'Huez at 60 -70 kph coming into each hair pin turn, riding the brakes hard, on a 42 C day. They need to make recommendations based on absolute worst case rider use case. At least if they are proper engineers, that is what they have to do and base all blanket statements to the public based on this because there is a chance that there will be some who will. They are bike wheels and need to survive fairly worst case riding scenarios.
On the other hand, if you are 150 lbs, and riding IM Florida on a flat course one a moderate day, the braking dynamics should be entirely different. So what's your use case? Heat build up should be fairly proportional to rider weight, starting speed, ending speed, and time taken to stop and ambiant temp and relative airflow over the rim (rider speed does not tell the full story, because rim cooling in an 40 kph headwind will be better than 0 kph wind).
So if your braking use case is fairly benign (I am 140 lbs, and mainly only riding WTC and local tri courses), then I'd rather have decent stopping power in an emergency, because the reality is that i am no where close to the worst case rider use case.
What do you think? Why ride around with shitty stopping power that is recommended against mainly to protect Bonetrager against a lawsuit from a worst case rider?
Now you guys may have the final laugh when at 140 lbs I somehow manage to superheat my rims and blow out a front wheel at 75 kph, but I'm generally not that type of "braker". There are ways to brake so your rims have a chance to cool on a long mountain descent if needed. We learned that old school riding in the 80's in the Alps :-)
