Wow...is it possible to be so balanced so as to swim well with an ankle band? I've always swam faster and more comfortably with a pull buoy(although don't use one for more than a couple hundred yards during warm up) so I know that my legs must drop, causing drag. Tried an angle band for the first time this week and the dropped legs/ increased drag was extremely apparent. I'm guessing my legs dropped 20-30 degrees below the surface and there was little I could do to raise them by pushing downward with my upper body.
I know that getting the legs up is the solution, but I find it hard to believe that one can actually balance the body such that the legs won't drop when banded, unless you're swimming at a 1:00/100. I usually do 100 repeats at a 1:30/100yd pace, not super fast, but I'm not a sinker either. Is there hope, or maybe trick?
