MadTownTRI wrote:
I’m bad at math... is it possible to back into an approximation mathematically of what would be applied to a forceplate using just a fancy accelerometer and my weight as Stryd claims, or are there too many variables ?
An approximation, yes. The basic math is pretty simple.
I experimented with this in my garage a 5-6 years ago, modifying an aftermarket insole. Given I was just operating at a hobbyist level, the data from low-cost accelerometers is inherently pretty noisy. And I had huge issues with things like consistency/calibration/fixing the accelerometers well in a shoe.
I decided, at the time, it wasn't the best way. And switched, instead to a direct pressure sensor embedded in the sole instead. It would effectively measure the compressive force between ground and foot. I ended with a design that measured pressure at 5 points of the foot. Similar to what I think the Brim Bros. tried to do for a shoe-based cycling power meter.
I had much more luck with this approach. I decided the insole wasn't great (they get wet, etc.), so I converted into a "data sock" with a little battery/processor pod over the achilles.
Handed the package off to a guy who looked for venture capital type funding (this was before GoFundMe, etc), but he didn't have any luck.
I'm not claiming this is the best way. Maybe Stryd or others have figured out accelerometers, etc, and they're brilliant.
I also did very little in terms of processing the data. I didn't pretend that I'd created a "power meter." I showed the marketing guy raw data that showed we could very accurately calculate stride rate, and get some decent-looking data about integrating force over time on each foot strike to calculate the energy transfer. But I told him not to lie that it was anywhere near finished, and warned that it would take work on the order of several Ph.D. theses to arrive at something like a true power meter.
