https://cyclingtips.com/...bon-clincher-safety/
Test video here https://www.youtube.com/embed/OlZvFPdLulI
On the surface, Alto Cycling’s test protocol was quite grueling. Each wheel was driven by an electric motor at a sustained 1,200-watt output, and 135lb of radial load was applied to simulate bike and rider weight. For the initial 20-minute round of testing, the brake lever was squeezed with a constant 7lb of force. If the wheel survived that, the lever was increased to 9lb, and then the test continued for another 20 minutes.
Alto should absolutely be applauded for the endeavor, and the fact that its rims survived such an ordeal is impressive and reassuring. But the testing protocol is subject to criticism. For example, only one sample per wheel model was used, which is hardly enough for a statistically valid conclusion. And according to Sweeting, the 1200W input force was chosen more for reasons of practicality, not empirical data collected out in the real world.
“The motor input was simply a number that was able to bring the wheel up to a reasonable speed and input enough power to fail the rims in a short amount of time,” he said. “We didn’t want any of the tests going over ten minutes, ideally, because it would make the video longer.”
Perhaps not surprisingly, Alto reports that its latest carbon clinchers performed the best by a wide margin. What was surprising, however, was that they were the only rims in the test that survived the complete testing cycle without catastrophic failure. Among the also-rans were such notable brands as Zipp, Bontrager, Enve, Mavic, Knight Composites, Roval, Boyd Cycling, and FSE, all of which failed Alto’s test with visually (and audibly) spectacular results.
So you create a test that does not replicate real world conditions all because the video may be too long?
Surprise that all of the wheels failed except theirs. Thoughts?
