Lock_N_Load wrote:
I have done two Ironmans and I did the second 45 minutes faster than the first. The differences in order of importance were:
1. Fitness on the bike
2. Proper pacing on the bike
3. Proper nutrition on the bike and on the run
4. Proper pacing on the run
If your bike fitness is poor then you will have to be VERY conservative on the bike or your run will be a death march. You are too late for changing much in this area but know that in my mind this is the most important factor for a good IM run.
You also can't go crazy on the bike during your race. You need to find that sweet spot at a low Zone 3 (maybe high Zone 2) FTP or HR where you can diligently maintain through the entire race. This takes a ton of discipline but it pays dividends.
You must fuel properly on the bike and you must maintain electrolytes and hydration throughout the run. If it's hot you must stay hydrated and use ice at the aid stations to stay cool. This is a must if you have a hot day. If you don't cool your body down you are dead. I also found that, at least for me, Coke is magic. I took Coke every other aid station and it helped a ton.
Finally, after you transition out of the bike TAKE IT EASY. Walk for a bit if you have to, then jog, then settle into your race pace. Also, if you have to walk the hills, walk the hills. Do not take risks your your pace and effort early in the run, this is dangerous for your second half. Be conservative on the first half and then if you feel you have it in you push the pace.
I think if you take the above into considerations and if you have put in proper "big days" in your training you should do fine in your IM run. Good luck.
This, this, this!!! My n=2 experience was similar. When I nailed these 4 things, my IM marathon PR went from 4+ hrs to 3:25 and my overall IM PR time went from 11+ hrs to sub 10:30 (on the IMWisc course), and that included walking the big hills on the marathon course.
The only other tidbit I would add to this is more philosophical than anything: The slower you start the run, the sooner you finish. Every time I've started the run slow and steadily picked up the pace, I put down a solid run/decent time (for me).
Good luck! Happy tapering! Enjoy the day, however it unfolds. Trust your training. Race YOUR race. Thank the volunteers. Get the crowds to do The Wave out in Verona.
Tad
It took awhile, but I finally discovered that its not the
destination that's important, but rather the journey.
