Has anyone used a GP 4000s 700x25 on a older P3C? I recently tried one and it rubbed at the top of the seat stays, but only when I stood up to climb. I'm not sure if I had the set screws backed out all the way in the horizontal drops, if that even matters. Anyone?
Re: 700x25 rear and 2007 P3C? [jellyfish]
The 23mm ones barely fit with wide wheels, surprised the 25mm fit at all.
I'm not sure you will be able to make that work. Moving the wheel back helps a tiny bit but probably not enough. Aligning it just right MIGHT work but I had to do that with 23 already.
I would just get 23s!
jellyfish wrote:
Has anyone used a GP 4000s 700x25 on a older P3C? I recently tried one and it rubbed at the top of the seat stays, but only when I stood up to climb. I'm not sure if I had the set screws backed out all the way in the horizontal drops, if that even matters. Anyone?Kat Hunter reports on the San Dimas Stage Race from inside the GC winning team
Re: 700x25 rear and 2007 P3C? [jackmott]
Thanks for the reply. I couldn't see any way to make it work, but thought I would ask for some help.
no dice on mine either. no issues with 23mm.
Formerly TriBrad02
Formerly TriBrad02
