stevej wrote:
milesthedog wrote:
I had another thread asking 1x folks about their gearing. There are some 15 and 17% sections of that climb and the first 1.6 miles avg's 8%. I'm thinking a gain ratio of 2.9 is the minimum I need
I'm assuming you are taking crank length into considering with those gear ratio's (using sheldon brown's calculator).
Yep, definitely.
So, on a 172.5, a 39/28 may be a tad bit easy if hitting that climb hard, using the climb to put a gap on the field before the 40 miles of descent and flat section (with one hill thrown in there). 39/28 would be 2.8. So, maybe a 39x27 (gain ratio of 2.9) would be a tad better. (DA 9100 11-30 has a 27, and 10sp has 11-27). For myself, using a 162.5 crank, 2.9 is a 50x36.
I'll be thinking about this as I mix some of the local climbs of similar length and grade into my training.
wovebike.com | Wove on instagram
milesthedog: Jul 5, 17 12:12
