4000S II Pressure and Crr
OK- slowtwitch just published an article on the new Conti's
http://www.slowtwitch.com/..._4000_S_II_3946.html
everything seemed normal, until I got to this chart. It implies that higher pressure is always better. That defies the ST wisdom on the subject, which claims that too high of a pressure isn't better than a more 'optimal' pressure. I'm sure we'd all give up some comfort for speed come race day. Should we?
Re: 4000S II Pressure and Crr [morey000] [ In reply to ]
that is correct, on a smooth surface, but roads are not smooth surfaces.
I was under the impression that higher pressure IS always better on a perfectly smooth surface. This testing was most likely performed on rollers or something similar, so the vertical "bouncing" that comes from running high pressure on a less smooth surface is not accounted for.
-Andrew
Re: 4000S II Pressure and Crr [jeffp] [ In reply to ]
Is there any evidence to suggest it's not correct on roads? Everything I've seen shows pretty good correlation between smooth and bumpy.
I think the reason to not go super high on roads is just comfort.
Optimal tire pressure for crr is dependent on surface smoothness, tire construction, rim width (indirectly) and total mass.
I know I'd never run more than 110psi during my races.
Re: 4000S II Pressure and Crr [trail] [ In reply to ]
Yes, there is plenty of evidence.
Higher pressure on a roller or velodrome is generally faster but that's as smooth as it gets. In the real world every little imperfection or even texture of the road (chip seal for instance) causes a very high pressure tire to bounce. Lower pressure allows the tire to deflect and remain in contact.
Conti uses a large smooth drum for Crr testing. Higher pressure is always lower Crr if the surface is smooth.
The fact that there is an "optimal" pressure comes from field testing on roads that have some roughness. It isn't that easy to determine and will vary depending on the tire, speed, roughness, rider weight, posture, bike deflection and damping, etc.
Just to give an extreme example the optimal pressure for MTBs on rough trails is <20 psi with fat tires.
Re: 4000S II Pressure and Crr [TH3_FRB] [ In reply to ]
Could you point us to it? (not trying to be a dick - genuinely interested). The only real data I've seen is AFM's one 1000Hz bumpy roller test, which appears to show Crr dropping with increased pressure all the way to 150psi for all the tires at about the same rate as the drop with the smooth rollers. Was there some mistake in the methodology - not allowing the bike to "bounce?" (although I seriously doubt a bike could bounce at 1000Hz), or some other experiment which refutes this.
You've apparently never ridden on my velodrome. :)
assuming that chart is taken from roller testing, it would be valid only on perfectly smooth surfaces.
Tom A's field test here (which you can find at aeroweenie.com along with every other useful bit of data in the world) shows how ON road CRR can start getting worse at a certain point:
That single field test certainly isn't the final word on the matter, Kraig Willet has tested this too and I don't think he came to the same conclusion.
further research would be great =)
Do we know when they'll be available to buy?
Re: 4000S II Pressure and Crr [jackmott] [ In reply to ]
Crr per se always decreases when you increase tire pressure because the tire deforms less. What can increase due to the pressure increase is dissipation due to slip force but you need a very good testing protocol (or analyze this just using analytical models) to capture this. Roller testing wouldn't work due to the double contact and the higher contact loads. A testing bench with a belt and a wheel (that's the setup that Continental uses) driven at the same speed wouldn't work either because you need to allow slip in the contact.
http://cds-0.blogspot.com
IIRC, I don't think Kraig's speed range was as large as my halfpipe testing, which could be a confounding factor...plus, he doesn't seem to be able to get the same sensitivity from his field testing...
Re: 4000S II Pressure and Crr [Epic-o] [ In reply to ]
Yeah...I'm thinking it's not so much what you describe above, but instead more of an increase in "suspension" losses (i.e. energy dissipation in the "squishy bits" of the rider) of the entire bike+rider system as the tire is "stiffened". Those losses aren't present on a smooth surface and the only losses are from the differences in force required to compress the leading half of the contact patch and what's returned to the surface in the trailing half.
For a single wheel on a bike, think of an automotive 1/4-vehicle suspension model where the "suspension" is the spring and damper represented by the rider contact points ;-)
Re: 4000S II Pressure and Crr [Tom A.] [ In reply to ]
The main issue about what you describe is what I like to call "energy path". The bouncing of the rider is induced by the pedalling loads but it's a movement in the vertical direction. Changing the stiffness of the tire you can modify how severe is that bouncing but I don't see an "energy path" that allows to recover some of that energy for propulsion purposes because the horizontal and vertical movement of the bike are pretty much completely decoupled.
The role of both rolling resistance moment and slip force on what it has been called Crr may not seem obvious because slip is not very common in typical road cycling situation. If you ride your CX bike on ice (something similar to increasing tire pressure a lot) it's more obvious, you can identify the two mechanisms that dissipates power: 1) Rolling resistance moment and 2) the product of slip force and wheel radius, a moment that also tries to decelerate the wheel. In that case, a traditional definition of Crr wouldn't be sufficient to capture total dissipation
I don't think you're following what I'm saying...I would suggest buying this ASTM paper and taking a look at it:
http://www.astm.org/.../PAGES/STP34599S.htm
Quote:
Abstract
A linear model for evaluating the influence of road roughness on total vehicular rolling resistance is presented. This model considers rolling resistance to be the result of three energy dissipation mechanisms:
(a) smooth-surface rolling losses,
(b) energy dissipation in the tire due to road roughness, and
(c) losses in the suspension system due to relative motion between sprung and unsprung mass.
The first of these mechanisms is completely dependent on the properties of the tire, specifically, hysteretic losses accrued from tire deformation during rolling. The other mechanisms are dependent on road profile, vehicle velocity, and vehicle parameters, as well as tire properties.
Calculation of losses due to rolling resistance are made by means of a quarter-car model to evaluate the relative magnitudes of the various mechanisms. The results obtained indicate that for rough road surfaces, the losses due to the roughness-related mechanisms are comparable to those arising from smooth-surface hysteretic losses.
It would be interesting to know what's their definition of "losses" but my level of geekiness isn't high enough to pay for papers ;). Just reading the abstract, I can see that they aren't differencing mechanisms that tend to decelerate the wheel (the first one) thus having an effect on horizontal motion to those that doesn't (the other two) so applicability here may be limited.
I will write a post about this someday
It's not about horizontal differences, it's about torque...a torque resulting from the difference in VERTICAL force going into the contact patch in the leading half of the contact patch and the force pressing on the road in the trailing half. If energy is transmitted through the tire and dissipated elsewhere, then it can't be "returned". None of this is anything new in the vehicular world.
Once again. The bike isn't decelerated because the wheel is damping the irregularities (producing losses). There are two decoupled movements (vertical and horizontal) and the losses due to one of them doesn't affect the other.
We can continue this through PM if you want
I've probably done more than 300 laps on multiple venues/days with varying speeds, all up mass, tire construction, pressures, etc, and haven't come anywhere near the ballpark of reproducing these results: http://www.aeroweenie.com/...ta/tire-pressure.jpg
My methodology produces results that are consistent with my own smooth/bumpy roller testing and wind tunnel results.
Kraig Willett
http://www.biketechreview.com - check out our reduced report pricing
Re: 4000S II Pressure and Crr [BikeTechReview] [ In reply to ]
What were your findings for on-road crr? Higher pressure is faster indefinitely?
I have a lot of the data and associated commentary on my site. You'll have to work at accessing it using the site search function. Sorry about that. At the time (years ago!) I did my best at reporting things in detail as I collected the data, not only for my benefit, but for the benefit of those doing their own field testing.
Subsequent to that, though, in a facebook post I alluded to a road surface condition that might throw a spanner in the works as far as my testing goes:
https://www.facebook.com/...p;id=142350229148866
(links within that fb post don't work anymore after I migrated to a new provider)...basically, I found that higher tire pressure isn't necessarily something as scary as some folks might lead you to believe...and, the modeling is tricky - it's quite possible that most people doing this type of testing mis-specify things.
Kraig Willett
