dfroelich wrote:
As Jackmott mentioned, it will only really be measuring speed...kinda.
The current produced by the generator will be somewhat linearly correlated to the wheel speed. Since the whole thing is buffered by a battery, there will not be any second to second resolution that would be able to translate into how that speed is changing (i.e. power). Even though, 15W isn't really the problem. You could potentially translate 3W of battery charging into 50W of rider power. You would just need to also be constantly discharging those amps because once it fills, you'd be reading zero. Further, the rate of charging (displayed watts) will not be consistent at various battery levels.
Best case, this would have error +/- a couple hundred watts. You would be much better off with that ~$150 powercal.
hmm how about having the roller on the chain of front crank's big gear .... I never use granny gear anyways. But thanks for the power tap ideas it has me ebay hunting now
