As the title suggest, I am trying to install a BB30 Quarq on a 2014 Venge, which I believe has a 46mm wide OSBB bottom bracket. I found a couple of threads on the Internet that said it was possible but that I needed the Sram BB30 Bottom assembly kit for the extra washers. I picked up a kit but I can't seem to find the correct spacing to remove all of the extra side-to-side play. Anyone have experience doing this?
Dumb question to start off, are you including the wavy washer?
With the spacers you cant get the wavy washer to compress at all? Or you're not including the wavy washer (and that would fix the problem)?
