excel help - strange behaviour...
Trying to format a CSV file for import into Great Plains General Ledger, in order to do so the sum of the "amount" column must equal exactly zero.
however, the sum of the column is 0.000000000944.....
in the column of numbers there are no amounts which go beyond the second decimal place. the problem remains if I use the round() function.
if I multiply the cell contents by 100 the issue disappears. if I then divide the multiplied cells by 100 to return to the original values the issue returns.
any ideas?
Swimming Workout of the Day: http://forum.slowtwitch.com/...ost=5784860#5784860;
Favourite Swim Sets: http://forum.slowtwitch.com/...m.cgi?;post=5004659;
Winner of the 2017 50 fly east coast Smackdown. http://forum.slowtwitch.com/...ost=6294538#p6294538
Re: excel help - strange behaviour... [JasoninHalifax] [ In reply to ]
JasoninHalifax wrote:
any ideas?
Sign up for a remedial Excel course.
How does Danny Hart sit down with balls that big?
How are the cells formatted?
Change the formatting on the cells in question to General, and you should be able to see any extended decimal places.
Try formatting the cells as Currency, that appears to do the necessary rounding.
1.231239 2.123817 -3.36 -0.00494
$1.23 $2.12 -$3.36 $0.00
TRUNC(target_cell,2)
[ This Space For Rent ]
Re: excel help - strange behaviour... [efernand] [ In reply to ]
It's not a cell formatting issue. I can see what is in each cell, nothing goes beyond 2 decimals
Spreadsheet has about 1200 rows, so it isn't huge, but too much to input manually.
Trunc() function didn't work. Sum of the column is 9.4434E-10
Re: excel help - strange behaviour... [burnman] [ In reply to ]
you may still have to plug this if after this you end up with a real rounding variance eh?
It's a known problem with Excel and really any floating point math on computers. The numbers aren't represented exactly as you'd expect.
Formatting the cells (including the sum) as Currency, should "show" you what you expect, even if internally, Excel has fudged the math by tiny amounts.
As you've seen,multiplying by 100 and treating everything as integers works, because computers are great at integer math.
You could use "=ROUND(cell,2)"
Edit: posted too fast - formatting as currency as efernand says should help.
Re: excel help - strange behaviour... [SailorSam] [ In reply to ]
If you perform arithmetic operations on the figures subsequent to this, then yes, you will have the same floating point issue. As a terminal step, though, it should suffice.
Assuming the numbers in question are in column A, then in column B put in the following equation: =(INT($A1*100))/100
The sum should equal zero... unless someone at Great Plains was doing some creative accounting.
"The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts." - Bertrand Russell
