Mesh WiFi Routers
Anyone had any luck with a mesh wifi router? I need to replace my current router, because our connections will drop or have problems that are fixed by rebooting the router. It looks like mesh seems to be the thing to get now.
Re: Mesh WiFi Routers [jmcconne] [ In reply to ]
I setup the Netgear Orbi about 2 months ago. Our home network speeds pretty much doubled throughout the house. Word of advise, if you use your own network file share, with Orbi anyway, it has to be ethernet connected. There is a usb 2.0 port on the main router, but it's essentially dead, only works for maintenance purposes, not for hanging a network drive.
Hammer Nutrition |
Rudy Project, ask me about 50% off
Altitude Multi Sport
Runners Roost Race Team
I considered it but went with a uniquiti wireless access point. Range is incredible and was only $100.
Team Beam
Re: Mesh WiFi Routers [mck414] [ In reply to ]
Any reason you picked the Orbi over the Google Mesh? Looks like it is $100 more, but I can't see why it is better.
Re: Mesh WiFi Routers [GREG_n_SD] [ In reply to ]
Do you have a one story or two story house?
More ethernet ports on the back of the main & satellite nodes.
Hammer Nutrition |
Single story.
Team Beam
The Orbi also has a dedicated backhaul for data transfer between the router and the satellite, meaning you won't have degradation of the wireless band. The Orbi is probably the most powerful "mesh" solution out there that's easy to use. Best route to go though is using a Ubiquiti access point into your current router - cheaper, and much stronger coverage than anything else. This also assumes though that you can run a hard Ethernet line to the access point.
