Honda mowers are the best
I have a three year old Honda mower. I treat it like shit. Haven't changed the oil yet, don't even have a clue when I am supposed to do that. Leave old gas in it over the winter. Don't treat the gas that I do put in there... etc, etc...
Anyway, two nights ago I emptied the old gas and filled it with new gas (actually put stabilizer in this time) and after a few pulls got it going. Fast forward to last night when I was actually going to mow the lawn. 1 pull. Boom. I love Honda.
How does Danny Hart sit down with balls that big?
Re: Honda mowers are the best [BLeP] [ In reply to ]
"Never half-ass two things. Whole-ass one thing." -- Ron Swanson
My craftsman (B&S) did the same thing last night. It's only 2 years old though.
I suppose I should check the oil.
Never put stabilizer in.
Swimming Workout of the Day: http://forum.slowtwitch.com/...ost=5784860#5784860;
Favourite Swim Sets: http://forum.slowtwitch.com/...m.cgi?;post=5004659;
Winner of the 2017 50 fly east coast Smackdown. http://forum.slowtwitch.com/...ost=6294538#p6294538
My Troy-Bilt is the same way. Especially the 2-stage string trimmer, by all rights that thing should never run again, but it does.
Hammer Nutrition |
Rudy Project, ask me about 50% off
Altitude Multi Sport
Runners Roost Race Team
First mow of the season every year and mine starts on the second or third pull every time with the gas from last fall in the tank. After that, every week is first pull.
Best indeed.
"Perhaps I'm chock full of inner demons"
I bought my Toro used for $100. That was eight years ago, I changed the oil once. Runs like a champ.
Is it the same engine as your Civic?
Re: Honda mowers are the best [Old Hickory] [ In reply to ]
No, this one actually runs.
Re: Honda mowers are the best [JasoninHalifax] [ In reply to ]
I have a craftsman as well. Inherited it from my Grandma when she passed away 10+ years ago. Mower is at least 20 years old. I never put stabilizer in and don't remember the last time I changed the oil. Last weekend was the first time I mowed the lawn this year and it started first pull.
I have a Honda, too. I sharpen blades, change oil, replace the spark plug and air filter every spring after running it down to very little gas in the fall. Top off the gas with fresh 93 octane stuff and it takes about 10-15 pulls to get it started the first time.
I'm doing it all wrong.
Travis Rassat
Vector Cycle Works
Noblesville, IN
BikeFit Instructor | FMS | F.I.S.T. | IBFI
Toughman Triathlon Series Ambassador
Lawn Boy rules. I have a 4-cycle Silver Series mower that's >10 years old and looks like a complete POS but starts on the first pull just about every time. I do run the gas out of it at the end of the season but I can't remember the last time I changed the oil or the plug. I've replaced the pull cord and several cables but that's about it for maintenance apart from sharpening the blade every now and then. The housing that contains the pull start cable/mechanism got so loose that the vibrations while it was running wore away the rivet holes until it finally pulled right off of the body. Now, you have to set the pull start mechanism on top of the flywheel and hold it in place with one foot while you pull, and then lift it off the mower - pretty janky, but it works. When it finally refuses to start easily, I'll get a new one but until then...
_________________________________________________
"The will to win means nothing without the will to prepare" - Juma Ikangaa
http://www.litespeed.com
I have a Ratillio mower! Mexican brand, best mower I've had!
I had an old something or other, forget the brand, with an MTD engine. replaced the pull cord once, and the blade after I hit that piece of granite in the yard. and that's about it.
Gave it to a friend who was getting back on his feet when we got the craftsman, it's still running too. The old one has to be at least 15 years old by now, my wife bought it second-hand back in '08.
Re: Honda mowers are the best [Travis R] [ In reply to ]
I have the exact same issue with my mower and in researching this a bit it appears to be an issue with the autochoke on the engine. I think there may have been a recall by my engine doesn't appear to be covered by the recall, despite it having the same issues as those that were. I haven't gotten far enough to figure out the solution.
Re: Honda mowers are the best [mck414] [ In reply to ]
Mine is actually a Troy-Bilt but the motor is Honda, you know, the part that matters.
Back in the day (1960's), you were lucky to get 3-4 years out of a lawn mower. That was with putting in new spark plugs, changing the oil, cleaning the air filter, putting in white gas over the winter, etc.
Everybody makes better lawn mowers today. (Are any lawn mowers manufactured in the USA these days?) I had a Craftsman that I bought in 1996 for less than $150. Never did anything except fill it up with gas and once in a blue moon adding a little oil (but I never changed the oil). Last summer, the starter rope broke. The plastic wheels were starting to disintegrate and the grass catcher bag had some holes in it by then. It was easier to go out and buy a new Troy Built than to get the starter rope replaced. Lo and behold, the owner's manual on this mower specifically says there's no need to ever change the oil, just add oil when/if you need to.
Bliss.
Some say "I can". Others say "I can't". Both manage to be correct.
On my essentially 3 rd one. They are good. Starts first pull almost every time. First one was my brothers who I used to live on the same block. Both used it for about 10 years, along with another neighbor who joined in the last 3 years before something went on it. I forget what broke but it wasn't worth fixing. Brother is a mechanic so it was a part issue. Got another one and for three years before myself and the other guy using it moved we beat the hell out of it. We always leave gas in it over the winter and I don't know that we've ever done anything other then sharpen blades. Unless my brother was keeping up with oil and all that stuff. But I doubt it considering he'd leave it outside in the rain at times.
Until I get the blessing to buy a tractor this thing will get beat up pretty good.
The spring thaw must be occurring. The Canadians are talking lawnmowers.
I'll be what I am
A solitary man
Re: Honda mowers are the best [SkipG] [ In reply to ]
Jose Ratillo? How often does he mow your lawn? That guy is great!
TDS is real: https://en.m.wikipedia.org/wiki/TDS
Re: Honda mowers are the best [last tri in 83] [ In reply to ]
I was the last holdout on the street. I was ordered by my wife to mow since "we have the worst lawn on the street!".
Re: Honda mowers are the best [CaptainCanada] [ In reply to ]
every Monday, he only has one name Ratillio. He said yard look no good, 2 month me make better. He is a grass magician!
We bought a Honda HR194 in 1989. We have changed the oil every five years or so and had a tune up / cable replacement service done four years ago. The only preventive maintenance we have ever done is closing the fuel petcock after every use and letting it run out of gas.
I have a personality disorder, I don't drink coffee...
I have a craftsman that's at least five years old. I've never done any maintenance on it beyond sharpening the blade and it keeps running.
Re: Honda mowers are the best [Perseus] [ In reply to ]
Are you guys sharpening your own blades, or taking them in?
If you are doing it yourself, how?
Re: Honda mowers are the best [efernand] [ In reply to ]
I bought a bench grinder at a yard sale for $10. I'm pretty sure the thing is at least 40 years old, but it works great. Just youtube a video and you can do it yourself in 5 minutes. Just make sure you balance it right or you will wear out the bearings in the mower.
