Riser block
Looking for a Retül or similar front wheel riser block/leveler.
thanks
Retul Certified Fitter. gebioMized Pressure Mapping http://www.PedPowerPerformLab.com.
Retailer of Wahoo Fitness, Sable Water Optics, Enve Composit, Giro and more.
Zone3 USA Ambassador - use code DEAN25 for 25% off
http://www.OasisOne-Twelve.com - The ultimate hands free hydration system.
http://athlinks.com/...dv.aspx?rid=19354499 - results.
Re: Riser block [hideano] [ In reply to ]
Does Purely Custom work the same way?
Jeremy Quijano
Kona Swim Bike Run
Shop Manager
Wesley Chapel, Florida
Custom Frames @ Quijano Bike Co.
Re: Riser block [CrackedHeadtube] [ In reply to ]
that one is crazy expensive!
A friend of mine is making this one for $249, I'm biased but I think it is better that the others on the market for way less money.
http://blueliquidlabs.com/...fitting-wheel-riser/
He's got a degree in Mechanical Engineering and machines them himself so I'm very confident in the quality. It even has the ability to measure the incline of the bike after you set it to level so you can look at riding position during a simulated climb.
Brian
Re: Riser block [bmaclean] [ In reply to ]
thanks for the info. I just purchased a Retul one last week since I had a discount.
