Cleat fitting issue
I was hoping to get some suggestions from ya'll. I was fitting a co-worker's cleats. He said he feels like his left foot is falling off the pedal on the outside. I moved his foot out and wedged it, but he says he still feels like his foot is falling off. I was thinking of putting on a pedal extender. Any other thoughts/suggestions?
Re: Cleat fitting issue [jhodom925] [ In reply to ]
A few more 'eliminate the possibilities' diagnostics to isolate what might be causing the issue.
does he have this same sensation in a different brand of shoe
does he have the same sensation in same shoe, different pedal
check that the pedal spindle isn't bent
Anne Barnes
ABBikefit, Ltd
FIST/SICI/FIST DOWN DEEP
X/Y Coordinator
abbikefit@gmail.com
Was the first wedge installed in a "varus" position (thick side-inside)? Try installing it in a "valgus" position (thick side-outside).
Ken
Ken Nowakowski
ken@probikesltd.com
http://www.probikesltd.com
Re: Cleat fitting issue [Ken Nowakowski] [ In reply to ]
This is a fairly common complaint. I hear it at least once every two weeks. The solution is almost always the same.
First - Stance width and wedging are generally two different things. They certain can relate but there needs to be another reason for adjusting the stance width.
Here is a good read http://www.bikefit.com/s-13-road-bikes.aspx#Feet
Did you measure the tilt and angle of his foot? There can also be some good information for you here http://www.facebook.com/bikefitsystems?ref=hl
Lastly there is a cheap but excellent on-line course to help guide you through this. You can read more about it here. http://bikefit.medbridgeeducation.com/courses/details/bikefit-foot-pedal-interface
Anyone reading this that would like a NICE discount code for taking the online course just emails Paul at BikeFit.com
Anne or Kent can take it from here.
Good luck
Swifty
Well, valgus is one-in-a-million, and wedging and stance width are two different things.
The OP doesn't say how many wedges or what pedal system, but if we eliminate other possibilities such as those I wrote earlier, then you should wedge more. Stacking 4-5 under the cleat isn't uncommon, plus adding 2-3 inside if necessary (as long as it doesn't choke up the fit of the shoe). My personal record for wedging alone was six on the outside and three on the inside. Uffdah! More wedges means longer screws....
I have had the experience of not wedging enough, being too conservative, and so don't provide good solution for rider.
I do recommend the online class Swifty is promoting, btw.
Anne Barnes
ABBikefit, Ltd
X/Y Coordinator
abbikefit@gmail.com
