Classifieds
Post deleted by garrytri
Re: trek speed concept frame and parts gen 1 & 2 sram Etap speedplay zero [garrytri]
Re: trek speed concept frame and parts gen 1 & 2 sram Etap speedplay zero [siegfried08]
requested items have been set aside for you
Re: trek speed concept frame and parts gen 1 & 2 sram Etap shimano di2 speedplay zero [garrytri]
What is the length and tooth count of the 6800 crank?
It's a little hard for me to tell, are you selling the full cockpit upgrade kit to the 7.5? Aerobat, stem, cover, etc? Are you asking $475 for that stuff?
Price for .....
15 mm mono spacer
speed fin and attachment bolts
attachment bolts for front brake cover
pad wing
shipped to Philadelphia
Also....regarding the seatpost, is that carbon and will it work with a 7.5 bike if it is?
15 mm mono spacer
pad wing
Re: trek speed concept frame and parts gen 1 & 2 sram Etap shimano di2 speedplay zero [ridenfish39]
Oh yeah, if you have a gen 2 speed box I'm interested in that as well
Re: trek speed concept frame and parts gen 1 & 2 sram Etap shimano di2 speedplay zero [kyle h]
i have 3 ultegra cranksets 2 x 170 and 1 x 172.5 i have mid compact and standard sizing available
Re: trek speed concept frame and parts gen 1 & 2 sram Etap shimano di2 speedplay zero [Calvinbal6]
everything you need to do the switch, every component needed to do the upgrade including all the screws
let me know if thats clear enough
Do you still have the 7.5 upgrade?
Please reply,
Thanks!
I ride to stay sane, and married.....sort of
Please reply,
Thanks!
Re: trek speed concept frame and parts gen 1 & 2 small and medium sram Etap shimano di2 speedplay zero [garrytri]
What size is the helmet?
PM sent re bike
Are the straight mono extensions available? If so, what is the length, and are they uncut?
wovebike.com | Wove on instagram
Re: trek speed concept frame and parts gen 1 & 2 small and medium sram Etap shimano di2 speedplay zero [NEW]
I'll take both 600mm di2 wires if they're still for sale! Pm sent!!!
Speed kills unless you have speed skills!!!
Re: trek speed concept frame and parts gen 1 & 2 small and medium sram Etap shimano di2 speedplay zero [playero]
let me check what's remaining in my build kits
cheers
cheers
Re: trek speed concept frame and parts gen 1 & 2 small and medium sram Etap shimano di2 speedplay zero [milesthedog]
13.5'' s-bends remaining .5 '' has been cut
cheers
cheers
Re: trek speed concept frame and parts gen 1 & 2 small and medium sram Etap shimano di2 speedplay zero [unitedathletica]
Is the Di2 brake battery cover available?
Plus also interested in the DI2 cables and front function if they're available.
Thanks, Jon
Thanks, Jon
Re: trek speed concept frame and parts gen 1 & 2 small and medium sram Etap shimano di2 speedplay zero [JonD71]
sent PM
2019 TeamZoot Southeast Region
PM Sent
Do u have the 35mm riser still
Follow me on Twitter @CK21TRHC
I use what I love: ISM, Blue70, Trek, FLO
Re: trek speed concept frame and parts gen 1 & 2 small and medium sram Etap shimano di2 speedplay zero [ck21trhc]
Is this available? Do you have a picture of it?
di2 Gen 1 7970 dura ace
Shimano Dura Ace Di2 ST-7971 10 speed SM-EW79A-I front wiring kit/junction box for time trial/triathlon bike setup $130
Yeti racer: Mar 15, 17 9:24
Re: trek speed concept frame and parts gen 1 & 2 small and medium sram Etap shimano di2 speedplay zero [Yeti racer]
Hi, I sent a message regarding the Di2 wires I'm interested in. Thanks
Hi,
regarding your SC armrest cradles, do you know the distance between 2 attachment points ?
It's for a Speed Concept Gen1 and holes must be 3cm center/center (or 1.5cm between 2 holes because when the cradles are attached, there is one hole that is free between the 2 others so 2x1.5cm=3cm).
