Wheels! ENVE, Roval, Chris King
Few things for sale, all prices include fees and shipping:
ENVE 3.4 Tubular 11 Speed CeramicSpeed Hubs - $1,699
These ENVE 3.4s are in PERFECT condition. The hubs are Rovals. They have DT Swiss internals so spare parts are easy to find. They also feature CeramicSpeed bearings which spin like butter. The freehub is SRAM/Shimano 7/8/9/10/11 compatible as well as Campagnolo 11. No pads or skewers included.
Roval CLX 40 SRAM/Shimano 8/9/10 Speed CeramicSpeed Hubs - $1,249
These Rovals are in great condition with barely any signs of use. They include tubes, tires, skewers, and the brake pads. The tires are Specialized Turbo Pros in 25mm and have plenty of life left. The internals of the hubs are DT Swiss so if you wanted to swap out the freehub, it would take 10 seconds, and then you're 11 speed or Campy compatible. They weigh a VERY light 1378g.
2014 Chris King R45 20/24 11 speed SRAM/Shimano Wheelset - $749
This wheelset is really quite fantastic. They're light enough to disappear under you, they're durable enough to use as a training wheel, but on top of all of that they perform well enough to be race wheels. The rims are the nearly the same specs as a Pacenti SL23 rim being 22mm deep (instead of 26mm) and 24mm wide, except manufactured by Kinlin. The brake track is smooth and exactly what you'd expect from anyone else. The rims weigh ~440g so they're not even close to being heavyweight. The 24mm external width means everything is just better. I can't really explain it, you really have to just try it. The Chris King hubs are so smooth, anything you thought about these hubs was probably right. They're not annoyingly loud, they just sort of buzz in the background when you coast. It's really a classy noise compared to the annoying clack of other hubs. The 45 points of engagement is really noticeable compared to the industry standard of 24.
Build details:
Rims - Kinlin XR-22T 22x24mm rims
Spokes - Sapim Laser 20/24
Nipples - Sapim 14mm Alloy
Hubs - Chris King R45 Black 11 Speed SRAM/Shimano
Other - Velocity Veloplugs
Re: Bunch of stuff for sale! Cervelo SRAM Zipp [dudemanppl] [ In reply to ]
Not trying to be a jerk, but BB30 does not fit in every BB. You can likely find an adapter for most, but not all.
BB90 for example won't take 30 mm spindle
Re: Bunch of stuff for sale! Cervelo SRAM Zipp [zachboring] [ In reply to ]
Oh well literally everything but BB90 because Trek uses a weird system with bearings that aren't pressed in.
Bearings are pressed in.
Also, getting a bb86 frame to work might be tricky too.
Glws. Just didn't want anyone to get mislead
Edit: nevermind I see fsa makes an bb86 with 30 mm bearings
Oh huh? I was under the impression Trek uses a system where the bearings are just slipped in like integrated headset bearings, I guess I'm wrong.
Won't fit frames with threaded bb either. Like the hollow tech or GXP. Or mine which uses pressfit gxp (I think...someone with a foil can correct me if I'm wrong)
Powered by Dalzell Coaching
Re: Bunch of stuff for sale! Cervelo SRAM Zipp [jsiege11] [ In reply to ]
It will fit, with a special bb. Not ideal but totally possible. Quarq (and rotor i believe) are unique in that their spindle is a full 90 mm for a bb30 crank. Most bb30 cranks are 68mm and thus wouldn't work in a threaded or pressfit frame
So will the bb30 quarq work in a threaded bb frame (eg last gen p2, s2)? Sorry for the hijak! Free bump!
Yes, but with a special bb.
Yup they're about 50 bucks.
Link please.
Re: Bunch of stuff for sale! Cervelo SRAM Zipp [Tyrell] [ In reply to ]
http://www.bdopcycling.com/Bottom%20Brackets-ADAPTOR%20BSA%20to%20BB386.asp
You need a BB386 compatible crankset. SRAM's non-Quarq BB30 cranks will NOT work. Same with Specialized, FSA, Cannondale, etc. Just ask me if you have any compatibility issues you'd want to clear up.
Re: Cervelo S5 VWD 56cm, Zipp 404 Firecrest Clincher V9, SRAM Red 22 Quarq [dudemanppl] [ In reply to ]
Bump! Prices reduced.
Re: Cervelo S5 VWD 56cm, SRAM Red 22 Quarq BB30 175mm 53/39t [dudemanppl] [ In reply to ]
Bump!
Prices lowered!
Prices lowered again.
Re: Big sale with cool things! [dudemanppl] [ In reply to ]
Bump with new stuffs.
Prices Reduced!
Re: Big sale! S-Works Tarmac, Cervelo S5 VWD, Roval CL40, SRAM Red Quarq [dudemanppl] [ In reply to ]
Prices reduced again!
Re: S-Works Tarmac Vino, ENVE 3.4 Tubular, Roval CL40, Quarq Elsa BB30 170mm [dudemanppl] [ In reply to ]
Items added, bump.
Did you sell the s5?
Re: S-Works Tarmac Vino, ENVE 3.4 Tubular, Roval CL40, Quarq Elsa BB30 170mm [kppolich] [ In reply to ]
Yes I did.
I did this successfully at one point with my Giant, bought the enduro bb86-bb30 adapters and it worked fine. To accommodate my Quarq at the time. But I have since switched back. It won't work with bb90 though.
Bump!
Re: Bunch of stuff for sale! ENVE, Di2, Roval, Chris King, Cannondale, SRAM, Look [dudemanppl] [ In reply to ]
Lots of stuff added, prices reduced.
