I'm selling my 2016 Quintana Roo PRSix, size 56. Ridden for most of last year. I recently serviced it, adding a bunch of new components, then decided it probably won't get much use this year. Here are the specs:
Frame: 56cm. Shows some scuffs from transportation and use, and some evidence of tire rub in the rear triangle. All stem hardware/risers will be included. Includes QR QBox. I did have to re-epoxy the threaded panel that mounts the QBox to the frame. Will add photos of this.
Cockpit: Zipp Vuka Bull Carbon, Zipp Vuka Carbon S-Bends (NEW), SRAM carbon brake levers.
Wheels: Zipp Firecrest 808. Note the "two-tone" decals: stealth black on the drive side, red on the non-drive side. I also have a Catalyst carbon wheel cover (not pictured), which I'll include.
Drivetrain: SRAM carbon R2C shifter (NEW), SRAM Force 1 rear derailleur (has a couple scuffs on derailleur body), SRAM Red chain (NEW), SRAM 11-36 cassette (nearly new; only 1-2 rides).
Brakes: TriRig Omega front, Ultegra direct mount rear.
Crankset: Quarq Riken with 165mm crank arms OR: no Quarq/crank, but I'll include a new 52T X-Sync chainring (see options below).
Saddle: ISM Attack
Asking:
As shown: $3000 shipped. Subtract $300 if you don't want the Quarq. Subtract $1000 if you want it without the 808s.
Saddle: ISM Attack
Asking:
