Post deleted by Kocua495
Post deleted by Kocua495 [ In reply to ]
Re: Training Mask 2.0 [Kocua495] [ In reply to ]
Kocua495 wrote:
Check out what's in the masks.
https://youtu.be/uwli9S9iHLg
That URL didn't load, FYI
Re: Training Mask 2.0 [.david.] [ In reply to ]
Sorry. This link is better.
You can't buy happiness but you can buy a bike and that's pretty close.
------__o
----_`\<,_
---(_)/ (_)
Hump day bump. Use the training mask during your indoor sessions or during strength conditioning workouts.
------__o
----_`\<,_
---(_)/ (_)
Monday bump! Is it Friday yet?
------__o
----_`\<,_
---(_)/ (_)
Hump Day bump! Thanks for considering.
------__o
----_`\<,_
---(_)/ (_)
Do these have a special nitrogen tank that pumps N into your mask? Because that is the ONLY way to stimulate high altitude. High altitude relplaces the levels of o2 with N, not co2! Wearing merely a "mask" just causes increased levels of co2. Co2 causes your lungs to hyperventilate, because it slowly lowers the ph of your blood and makes it more acidic. This does not stimulate erthopoietin. Quite frankly, its unhealthy!
Furthermore, even if this did contain a tank of nitrogen. The few conclusive studies that showed true efficacy towards high altitude, showed the most beneficial results came from sleeping high and training low. If you train at high altitude, it limits your aerobic threshold, so your body has no ability to make gains from increased training stimuli.
Re: Training Mask 2.0 [phourgenres] [ In reply to ]
No nitrogen. I removed the word "High Altitude" to avoid the confusion.
The Elevation Training Mask 2.0 is the ultimate respiratory training device for breathing and controlling the flow of air delivered in to your body. The Multi level resistance system creates a Resisted air flow through flux valves into the Training Mask 2.0.When your body adapts to the resistance of Training Mask 2.0 your lungs will be trained to take deep breaths that use oxygen more efficiently.
------__o
----_`\<,_
---(_)/ (_)
Monday bump! Perfect for those track workouts or indoor trainer sessions.
PM me.
------__o
----_`\<,_
---(_)/ (_)
Happy Hump Day bump! Perfect for those door sessions! $40 + $6.80 S&H via priority mail.
Thank you for considering!
------__o
----_`\<,_
---(_)/ (_)
