Price Drops
Few things for sale, descriptions below: S-Works Epic Mountain Bike, Tarmac Pro SL3 Frameset 58cm,
Few Pictures of each below additional pictures can be provided. Or can be seen here:
http://www.pinkbike.com/u/corakita/album/Sale/
2011 Specialized S-Works Epic 29er $2200+Shipping
24 lbs as pictured
Frame: Size XL, Bottom Bracket is Enduro XD-15 Ceramic ($250 BB, old SRAM PF 30 I would wear out and have to replace 2x a year, the Enduro BB has lasted me for 3 years, just a simple regrease when needed, any respectable shop can do this. All Suspension Bolts and bearings were replaced at beginning of the year and still in good shape.
Bike has been ridden and raced, there are paint chips, scratches and cracks/chips in clear coat, all is cosmetic no structural damage, pics below.
Drivetrain: SRAM XX 2x10 except upgraded to X-O Type 2 Rear Derailleur (has roller clutch standard XX der does not, type 2 has better chain retention and shifting) and Rotor Rings 38/27 Combo (new this year). Rear Cassette is SRAM 1099 XX 11-36 (only raced on 1 season, great condition) and will include Shimano XT 11-36 as well that was trained on still has good life. New Rear Shifter installed and new cable, front shifter and cable and housing was replaced beginning of September. Brakes are SRAM XX have worked flawlessly for me, bled recently pads in good shape, 160 Rotors front and rear. Paint has worn off on levers from packing and shipping, Wheels are Stans Crest 32 hole, STAN's ZTR front Hub, American Classic Rear with Alloy free hub Steel Flanges so cassette does not bite into freehub. Hubs are in great working condition, great for light weight race wheels. Rims taped tubeless and valve stems will be included, tubes are installed currently. The rims are on last legs and will need to be replaced. Handlebar is Truvative Noir Carbon T40 Handlebar, with Ergon GS1 Grips (GS2 Carbon grips included), Rotor SP1 Seatpost, Specialized Phenom 143 Pro Carbon Saddle
Additional pictures can be sent
Tarmac Pro SL3 Frameset 58cm $900 Shipped
Last year of the standard BSA threaded BB on this bike.
Handlebar, stem and carbon seatpost included
Some small scratches on the frame, flash from camera makes them look much worse than they are, frame is very clean otherwise.
Wheelset or willing to sell each wheel separately: Set for $400, Front only $100, Rear $300
Front Wheel - Blackwell Research 50mm Deep Carbon Tubular Wheel, Conti Sprinter Tire with valve stem, skewer and carbon brake pads
Rear Wheel - Zipp 404 laced to American Classic Hub Rear 10spd Shimano/SRAM Hub (Is possible to upgrade to 11speed)
Wheelbuilder Aerojacket Cover custom made for this rear wheel to make it in to a disc option as well.
Continental Sprinter 700x22 Tubular and valve extenders included, light use on one other is new was pre-glued as a spare, no nicks or cuts in either both are in excellent condition.
Skewers and carbon brake pads included.
"Here's to the finely tuned athlete on the verge of greatness"-Romeo, Tin Cup
24 lbs as pictured
