Tiny Steel Cyclocross Bike, Baja Stryker II lights
Custom built DeSalvo frame and fork.
Columbus life steel frame and fork, Paint by Spectrum
26inch wheels
Custom for my tiny wife. She is racing UCI stuff this year, so no use for a cx bike with 26inch wheels.
$2000 OBO for everything.
Top tube length 48.5cm
Stand over 66cm
stack 48.5cm
reach 36cm
Seat angle 76deg
head tube angle 71.5deg
Build
Sram Rival right shifter and rear derailleur
Sram alloy left brake lever
Sram alloy crankset.
Shimano XT SPD pedals
TRP Euro X canti brakes
Shimano Ultegra cassette and chain
Bontrager alloy bar and stem
Bontrager saddle
Thompson elite seat post
Paul Components chain catcher
Wheels
Chris king classic hubs
Stans 355 tubeless rims with machined brake track 26in
Schwalbe CX pro tires (set up tubeless with Stans) 26in
Extras
2nd set of identical wheels (with SWEET pink hubs)!
1 Schwable CX pro tire. Wire bead. 26in
1 Stans 355 tubeless rim with machine brake track 26in
1 set of TRP Euro X canti brakes — partially cannibalized for small parts, but mostly intact
________________
Two Baja Design Stryker II light sets
lights, chargers, batteries and a shit-ton of mounts and such.
Work great, but have been heavily used for 4 years. I'm only selling because now lights have gotten so good that I can buy a 4oz flashlight that is just as powerful. These were the shit in 2011. I paid almost $800 for everything.
Yours for $100. Shipped.
Thanks for looking.
Let me know if you have questions.
Andy
Re: Roval Control Carbon 29 wheelset [AndyPeterson] [ In reply to ]
Are these still available? Can one run a non-tubeless tire on these rims (with a tube of course).
Re: Roval Control Carbon 29 wheelset [GreenPlease] [ In reply to ]
Still available.
Any tubeless wheelset, including these, can be set up with inner tubes. That is the backup plan if you ever flat on a ride (pop off the tire, boot it if needed, pull out the valve, put tube/tire back on, pump it up and ride away)
That said, tubeless is nice. And these set up particularly nice. And the tires I'm selling with them are pretty nice tubeless tires. If you are interested in the wheels, you will probably want to run them tubeless.
If, for some reason, you don't want the tubeless set up, I can give you a lower price for the wheels without the tires. I'll stillninclude the valves, in case you change your mind in the future.
Andy
bump
following
Are the hubs 6-bolt or Centerlock?
Are hubs DT 240/350 so that end caps can be changed?
-Thanks.
Hey, not to hijack your thread, but you mentioned having too many nice MTB wheels. Any chance some of them are 27.5 that you're looking to unload? I just got a rad new HT myself, and it wants some fast hoops.
-Colin
Any run that doesn't include pooping in someone's front yard is a win.
Re: Roval Control Carbon 29 wheelset [CCF] [ In reply to ]
-Colin
Nope. Wife is on 26. I'm on 29.
Good luck.
Andy
Re: Roval Control Carbon 29 wheelset [SpeedyChix] [ In reply to ]
-Thanks.
6 bolt
Good question about the hubs. They are clearly not just regular DTs. Specialized has made at least some cosmetic changes for the roval hubs. Specialized website says they have DT swiss internals.
Just searching around on the interwebs, it sounds like all of the DT build roval wheels with 15mmTA will take the DT 15TA --> 9mmQR adapter. But I'm not 100% sure.
I think even with DT 240/350 hubs the xd driver 142+ rears require a change of the whole driver body to change the axel config (that is, you can't just pop out something that makes it 142+TA and pop something in that makes is 135 9mmQR. I think. Again, not sure.
Thanks for looking
Andy
Thanks for the thorough reply. I'll dig about a bit more as I need std QR front and rear and am really seeking centerlocks for my application.
To any one else considering a wheelset like this, these are outstanding wheels and super fairly priced.
You'll be hard pressed to get these essentially new wheels for less. Jump on them.
Bump.
bump for the addition of the lights
Bump
and willing to consider offers
Andy
bump
One last bump before wheels and lights go on ebay
Could you send me a message at flegoupi at shaw dot ca
Thank you.
Re: Roval Control Carbon 29 wheelset AND Baja Stryker II lights [AndyPeterson] [ In reply to ]
sent you a pm on the wheels
Re: Tiny Steel Cyclocross Bike, Baja Stryker II lights [AndyPeterson] [ In reply to ]
bump for little cross bike
bump
bump
both still available
Interested in the cross bike, I messaged you
