SOLD
Brand new never ridden 2012 FELT F3 carbon fiber 56 cm road bike with top of the line SRAM Red components -- UHC Performance Modular Monocoque Construction carbon fiber frame -- very light (16 lbs w/o pedals) -- recent and completely assembled / tuned at professional shop (even has easily removable required reflectors) and ready to for it's first ride! Matte carbon/nickel color -- this is a stunner! Owners manual, serial number, etc available with purchase.Can be shipped or picked up in metro Atlanta if local to save shipping costs. Shipping to be paid by buyer.
SOLD
The core of the F3’s incomparable ride quality is its proven UHC Performance Modular Monocoque Construction carbon fiber frame and fork. Even more impressive than the F3's incredible light weight are the superb ride characteristics. With a perfect balance of lightweight zing, powerful pedaling stiffness and comfy compliance, it’s clearly in a league of its own. A precise SRAM Red drivetrain and SRAM S27 wheels, complete this dream ride.
Beyond all of the tech talk and specifics of this masterpiece is the simplicity of a perfect design, carbon fiber weight and the ease of a bike that responds to your touch as if it’s your own appendage. With each light tap, touch, caress, the bike knows what you want and goes where you say. It’s a sensational feeling.
Frame: Felt Road UHC Performance MMC carbon fiber w/ 3KP weave, InsideOut internal molding process, BB30 shell, external cable routing, carbon fiber dropouts & forged aluminum replaceable rear derailleur hanger, 912g;
Fork: Felt UHC Ultimate monocoque fork, InsideOut internal molding process, 100% carbon fiber Controltaper 1.125"" --> 1.5"" steerer tube, integrated headset crown race, blades, & dropouts, 328g;
Headset: FSA Orbit C-40-ACB 1.125"" --> 1.5"" integrated, w/ aluminum 15mm conical spacer, 1 X 10mm aluminum headset Spacer, 3 x 5mm aluminum headset spacer, Felt carbon fiber top cap & 7075 anodized aluminum bolt;
Stem: Felt SL 6061 aluminum 3D forged +/-7° rise, Ø31.8mm bar clamp, custom Cr-Mo bolts, 131g; 56cm=100mm;
Handlebar: Felt VS UHC Advanced DMC carbon fiber bar w/ 3KP weave w/ Felt Variable Shape ergonomic drop, 198g, Ø31.8mm, 56cm=440
Grips: Felt gel tape w/ Felt logos;
Bar Ends: Felt bubble-tech ""F Wing"" icon end plugs;
Shifters: SRAM Red Double Tap;
Front Derailleur: SRAM Force braze-on;
Rear Derailleur: SRAM Red;
Crankset: SRAM S950 Compact BB30, Red 52/36T; 172.5mm;
Chainwheel: 52T/36T;
Chainguide: n/a;
Bottom Bracket: SRAM BB30;
Pedals: n/a;
Chain: SRAM 10 speed w/ PowerLock;
Freewheel: SRAM 11-26T;
Brake Levers: SRAM Red;
Brakes: SRAM dual pivot w/ Swissstop cartridge brake pads;
Cables: SRAM Red by GORE brake & derailleur;
Saddle: Felt SL road saddle w/ nylon injection molded base, polyurethane foam, embossed cover & hollow Cr-Mo rails;
Seat Post: Felt UHC Performance carbon fiber post, forged aluminum head, lightweight twin side clamp bolt design, Ø27.2mm, 300mm;
Seat Post Clamp: Ø30.6 x Ø27.2 6061 forged aluminum, 2 x 5mm x 0.8mm Cr-Mo bolts, w/ steel nut-bar. 36g;
Rims: SRAM S27 AL Comp 27mm deep aluminum, 18H front, 20H rear;
Front Hub: SRAM S27 AL Comp 18H w/ low friction Japanese bearings & light weight quick release;
Rear Hub: SRAM S27 AL Comp 20H SRAM 10 speed compatible freehub body w/ low friction Japanese bearings & light weight quick release;
Spokes: Sapim CX bladed spokes, laced radial front; laced 1x non-drive, radial drive rear, brass nipples;
Tires: Vittoria Rubino Pro Slick, 700c x 23c;
Head Angle: 73 degrees; Seat Angle: 73.5 degrees; TT Horizontal: 545 mm; TT c-c: 532 mm; Head Tube: 120mm; Seat Tube c-t: 520mm; Seat Tube c-c: 472mm
SOLD
Chainguide: n/a;
Pedals: n/a;
Geometry listed below believed accurate but please check the website for this bike to precisely know your size in FELT F series Road Bikes.
oldslowguy: May 10, 14 6:52
