Brand New Cascade Fluid Pro Bike Trainer
Asking $275 obo plus shipping
Comes in original box
Why spend more on a bike trainer when you can get the same great results and high quality features at a better price? The new fluid design is quieter than leading competitors. The Cascade FLUIDPro is one of the quietest fluid bike trainers available and extremely stable. Plus, the patented Quick Connect System makes it very easy to use.
Features:
Heavier flywheel for better performance
Smooth progressive resistance
Double seals prevent leakage
Folds for easy storage or transportation
Industrial powder coated frame prevents corrosion
Robotically welded for precision performance
Front tire riser included
No Assembly required
Quick connect
Specifications:
Compatible Tire Sizes: 24"-29"
Watt Range: 0-900 watts
Roller Size: 1.49"
Length: 24" (61cm)
Height: 17" (43cm)
Width: 23" (58cm)
Weight: 32 lbs (14.5kg)
Max User Weight: 400 lbs
Shipping Weight: 36.6 lbs (16.6kg)
Front Wheel Block and Quick Release Skewer are included
Here's a stock photo of the trainer...
Features:
Quick connect
Specifications:
Roller Size: 1.49"
Length: 24" (61cm)
Height: 17" (43cm)
Width: 23" (58cm)
