Prices include shipping to the continental US vis USPS. If you're local (Spokane/CDA area) then you can pickup and I'll knock a bit off the price.
Fulcrum Racing 3 Two Way Fit - SOLD
Good condition - true, hubs spin smoothly, no biting on the cassette, bladed spokes, 1555 grams, 700c. Can run either tubeless or clincher tires. The hub is Shimano/SRAM 11 speed but I can include a spacer if you want to run it with a 10 speed cassette.
Bontrager Race Lite Handlebars - $30
44 cm wide, aluminum. Some scuffs around where the stem connects as well as some marks from the handlebar tape, no dents or dings.
Ritchey WCS 4x Axis Stem - $25
120mm 6 degrees. Some minor marks but otherwise in good condition. No rust or other issues with the bolts.
Cervélo Mach 2 Brake Set - SOLD
Take off from an older P2. I believe these were made by Tektro. Worked perfectly, just decided to try out a more aero brake caliper.
San Marco Ponza Trilon - SOLD
Taken off of an older P2. Some typical saddle wear, but exterior is in good condition (no rips or tears) still has good support.
Matt
Matt
