Classifieds
Re: FS: Roval Control SL 29 Carbon Wheelset [%FTP]
bump
Are these wheels still available?
Re: FS: Roval Control SL 29 Carbon Wheelset [Clip]
Yep
I'm interested. Can you tell me the front hub end cap sizing? It looks like quick release but is it 28mm or 24mm? Also, is the rear hub set up as 135mm spacing and quick release? There will be a marking of either 135mm or 142mm or 142 +.
Thanks.
Thanks.
not 100% sure on the width of the front. its 9mm qr, and given that the new thru options are 28mm, i'd guess its 24mm. and yes, the rear is 135mm qr.
I can almost see it in the fifth picture, the one of the front hub. Does it say for Rockshox? If you look closely, can you tell me what it says on the endcap?
Oh, BTW, the wheelset usually comes with skewers and a set of endcaps to change the front hub to 28mm, 24mm and QR15; and the rear hub to 135mm and 142 mm. If you have all of those, then you have everything to convert to all configurations.
Alright, checked it and it is definitely 28mm. Unfortunately I do not have the end caps.
