I have a like new pair of Jaybird Freedom earbuds in red. All items that came with it when originally purchased are included.
Asking $70 plus shipping
Description of item:
SPECS
AUDIO
Type: In-Ear Style
Noise-isolation: Passive
Impedance: 16 Ohm
Speaker sensitivity: 96 +-3dB At 1KHz
Output 5mW nominal, 10mW max
Total Harmonic Distortion <3% (1KHz, 1mW)
Audio Format: 16-bit Stereo
Codec: AAC, SBC, Modified SBC
Response Bandwidth 20Hz - 20kHz
Driver Size: 6 mm
BLUETOOTH
Bluetooth Version: 4.1, Multi-point
Frequency Band: 2.4 GHz
Profiles: Handsfree , Headset , A2DP , AVCRP , SPP
PAIRING
Number of Paired Devices: 8
Pairing passkey: 0000
INTEGRATED MICROPHONE
Type: MEMS, Omni directional, ultra low power
Sensitivity: -38dB +-3dB (Test conditions: 1KHz, 0dB = 1V/Pa)
COMPATIBLE PRODUCTS
Any A2DP Bluetooth stereo device
OPERATION
Operating: 32F - 113F (0C - 45C )
Storage: 14F - 122F (-10C - 50C)
WEIGHT & DIMENSIONS
Width: 0.92" (23.4 mm)
Height: 0.88" (22.4 mm)
Depth: 0.24" (6.2 mm)
Weight (With Fins and Tips): 0.57 oz (16.15 g)
Cord Length: 14.17" (360 mm)
AGENCY APPROVALS
BATTERY
Play Time: 8 Hrs* (4 hrs plus an additional 4 hrs with included charging clip)
Standby Time: 110 Hrs*
Charging Time: 2.5 Hrs
Quick Charge: 20 min = 1 hour Play Time Plus 1 hour of playtime via the charging clip
Charging: Charging Clip with USB connector and internal battery, Charger clip and USB cable included
AC power: DC 5V 500mA
Type: 60 mAh Lithium Ion in the device
*May vary dependent on usage, device & aging
Battery Voltage: 3.7V
Energy Voltage in Watt hours: 0.23Wh
Lithium Content: 0.019g
CHARGING CLIP / BATTERY PACK
Charging: USB cable included
Type: 125mAh Lithium Ion in the Charger Clip
Energy Voltage in Watt hours: 0.41Wh
Lithium Content: 0.033g
BUTTON CONTROLS
AVRCP Music Controls (Play/pause, next, back)
Call Controls (answer, end, reject call, etc)
General (Volume, pair, power)
IN THE BOX
Freedom Wireless Buds
Charging Clip
Comply™ Foam Ear Tips: S/M/L
Silicone Ear Tips: S/M/L
Secure-Fit Ear Fins: XS/S/M/L
Cord Management Clips
Cord Shirt Clip
USB 2.0 Charging Cable
Carry Case
WARRANTY
1 Year Limited Warranty
SPECS
AUDIO
Type: In-Ear Style
Impedance: 16 Ohm
Driver Size: 6 mm
BLUETOOTH
PAIRING
COMPATIBLE PRODUCTS
OPERATION
WEIGHT & DIMENSIONS
AGENCY APPROVALS
BATTERY
BUTTON CONTROLS
IN THE BOX
Charging Clip
Cord Shirt Clip
Carry Case
WARRANTY
